2003 Civic Throttle Position Sensor - Honda-Tech
Old 05-06-2007, 05:50 PM   #1
aree's Avatar
Default 2003 Civic Throttle Position Sensor
Hi all!
A month ago, my check engine light (CEL) came on after a 100 mile run. The light remained on for another 65 miles. I figured it was just the gas cap, so i tightened it and within minutes the light went off.
I drove another hundred miles last night and this morning when I turned on my car, the CEL went on again. As before I tightened the gas cap but it didn't help. So I took it down to Autozone and got the codes read. the code came to be P0122 (Throttle position sensor - low voltage). The mechanic said I'll be fine, and he cleared the code. Drove back home and no code yet, but I am compelled to think that this CEL is linked with the last CEL because both times the CEL came on after driving long distances.
Anyway, if the code comes back on, how can I fix it? also, If I continue to drive with the CEL on, will it affect my car's operations, or leave any permanent damage, or leave me stranded?
Thanks and regards
Aree
P.S. Car is a 2003 Civic LX 5MT, all stock with 38000 miles.
aree is offline   Reply With Quote
Old 05-06-2007, 11:20 PM   #2
aree's Avatar
Anyone? Please I would really appreciate a little input.
2003 Honda CR-V / P1457 EVAP Leak l3randon33 Honda Element & CR-V 5 04-25-2016 10:23 AM
CEL 3 and 9 cjwang2 Honda CRX / EF Civic (1988 - 1991) 1 04-16-2015 07:22 AM
CEL, B18 swap form 99 Integra into 97 Civic EX ClassyG Honda Civic / Del Sol (1992 - 2000) 6 12-13-2013 09:36 AM
CEL: P1456 Evap Code OEMJDM Honda Civic (2001 - 2005) 2 09-23-2012 10:03 PM
P1362 TDC sensor not reading. Car goes into limp mode. 2001 Honda Civic ex Honda Civic (2001 - 2005) 4 06-20-2009 09:27 AM
Tags
2001, 2003, 2005, accord, cel, civic, code, honda, p0122, posisiton, position, positioning, sensor, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
