Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Civic limp mode
Old 02-28-2015, 12:27 PM
kmarolla's Avatar
Default 2003 Civic limp mode
Hi, my name is Kevin, I live in California and i'm having a problem with my 2003 civic. It's a 2003 Lx 4 door with a 1.7. It hasn't been driven in a few years. I recently started to get it running again. When I parked it in 2012 it had a check engine light and was in limp mode. I checked it and it said crankshaft position sensor. I did all of the testing of the wiring and everything checked out good. So, I decided must be the sensor and I replaced it. It still never cleared the code and wouldn't come out of limp mode. Figured I got a defective sensor and swapped it out with a different one. Still didn't fix it. I did some research and found that the camshaft position sensor could be the cause. Again stated with the basics and checked the wiring and everything checked out ok. Now I'm on my second sensor and with installing those sensors the car will start and stall instantly. With the old sensor in the car runs but won't come out of limp mode. Thank you in advance for all of your help
Old 02-28-2015, 12:37 PM
Sanji
toyomatt84's Avatar
Default Re: 2003 Civic limp mode
Not trying to sound rude, but did you try resetting the PCM codes after changing out the sensor? The PCM will hang on to old codes for a while, unless you clear them.
Old 02-28-2015, 12:53 PM
kmarolla's Avatar
Yes after every sensor I installed I erased all codes
Old 02-28-2015, 12:57 PM
Sanji
toyomatt84's Avatar
Hmm... potentially could have a wire break somewhere so that the sensor is not sending the signals all the way to the PCM.
Old 02-28-2015, 01:01 PM
kmarolla's Avatar
I've already checked all of the wiring and everything checks out fine. Just don't understand how with the old sensor it runs in limp mode and with the new sensor it doesn't run. It also doesn't throw codes
Old 02-28-2015, 01:41 PM
Raihan's Avatar
Check your timing chain.
That could be stretched.
Old 02-28-2015, 02:26 PM
kmarolla's Avatar
It has a timing belt with less than 50,000 miles on it
Old 02-28-2015, 03:28 PM
xci_ed6's Avatar
hmm, you have good progress so far.
Can you read the sensor signal? You may need an oscilloscope, but there are new digital versions that will work.
I do want one of those, btw, my old one was the vacuum tube type, like a big old television thing! Very cool, but maybe to a weird guy like me.
But basically, they let you see the sensor, the wheel, everything. Test it at the ECM if possible, it lets you make sure that the signal actually gets there.
Old 02-28-2015, 03:29 PM
Former User's Avatar
Post the exact code that was thrown.
With the new sensor installed, what code(s) is thrown?
With the old sensor installed, what code(s) is thrown?
Old 12-10-2015, 07:25 PM
Rogelio_Lozano's Avatar
I have the same problem, replaced 3 crankshaft sensors, 2 O2 sensors, and catalytic converter, and timing belt. I also replaced the spark plus. Did you ever get the problem fixed???
Old 12-10-2015, 08:34 PM
kmarolla's Avatar
I took it to a mechanic. The timing belt was off 1 tooth and they had to get a crankshaft position sensor from Honda. Not 1 I bought off the Internet.
Old 04-13-2016, 05:53 PM
backinblue92's Avatar
Interesting it threw a code for the timing belt being off a tooth. My 96 was off a tooth after a timing belt job which I caught a week later when I went to make sure all was well after the new belt. But it never threw a code, then again, the early obd2 is basically obd1.5 compared to the versions which began in 2000.
Clarkscivic802
09-03-2016 04:04 AM
Soup Slayer
08-20-2013 08:15 AM
cricket1001
11-15-2011 09:59 AM
99d-series
05-01-2009 08:56 AM
Fatty_1775
01-26-2009 10:00 AM
Quick Reply: 2003 Civic limp mode
