2002 Civic EX Codes P1298 & P1457
I've had these codes(P1298 & P1457) on and off for 2 years they seem to always turn off when its cold out.
I tried to solve P1457 by replacing the canister purge valve but guess what its still here . I tried to do a smoke test at the valve next to the valve cover and under the intake but was not able to blow air through it. The way I was doing this was removing the valve and with pvc tubes hooked up to the vacuum lines I smoked a cigar and breathed the smoke into the lines. Was able to breath into the line going into the fuel rail? but not the one heading the other way. I am assuming the p1457 is a leak but would like advise on how to find it or solve the problem.
Now onto the P1298, I ordered and I hope it does the trick. I'm worried that it doesn't how would I go about properly diagnosing it. I'm may need help recognizing parts but I'm very mechanically inclined.
I did do the head gasket last month and saw no broken hoses, I would like to try to solve this ASAP so I can sell the car since my wife just bought a new car.
Re: 2002 Civic EX Codes P1298 & P1457
not even a search? couldn't find any evap leak yesterday all the lines were good even the one on top of the gas tank but is there a place it dumps out of the system into the frame?
For the P1457 code...I have to ask, have you checked the fuel cap? Or changed it out? I had this issue before and all I had to do was order a new OEM fuel cap for my 02 lx and it was gone.
P1298 the part you ordered should rectify the load issue. Let us know if it doesn't I had a buddy who had this issue and he ended up installing a new ground kit all around and it fixed the code.
Gonna get a gas cap today I'll be pissed if it does it lol
F20Cdriver
02-21-2015 07:55 PM
92hatchattack
05-15-2006 04:34 AM
