2002 Civic A/C Light comes on when heater is switched to windshield defrost. - Honda-Tech
Old 11-09-2006, 08:57 AM   #1
jlukins's Avatar
Default 2002 Civic A/C Light comes on when heater is switched to windshield defrost.
My 2002 Civic A/C Light comes on when I turn the heater switched to windshiled defrost.
In this position, I cannot get the A/C turned off.
I have to turn the heater switch from defrost to floor heat - then I can press the A/C button & it goes off.
Maybe I could just pull the A/C fuse.
Any suggestions would be appreciated.
John Lukins
jlukins is offline   Reply With Quote
Old 11-09-2006, 09:00 AM   #2
flipmoderacer02's Avatar
its normal, A/C light is suppose to come on when you have the windshield defrost on
flipmoderacer02 is offline   Reply With Quote
Old 11-09-2006, 09:13 AM   #3
jlukins's Avatar
Default Re: (flipmoderacer02)
Thanks for the quick reply.
Is this unique to Honda.
Usually you turn on the A/C and the condensor motor kicks in & you fuel economy goes to the floor.
Not the case with Honda?
John
Old 11-09-2006, 09:23 AM   #4
Rennen's Avatar
1) Have the car turned off.
2) Turn the "air condition position" **** to the left all the way (counter-clock-wise).
3) Hold the "air-recirculation button" and the "A/C" button "DOWN". (don't touch the "defrost" button)
4) Start the car with the "BUTTONS" held down, and wait for 7 seconds.
5) All done. You can turn the "A/C" off and on now.
P.S. To turn the original feature back on, repeat all steps, but for "STEP 2", turn the **** all the way to the "right" (clock-wise).
Rennen is offline   Reply With Quote
Old 11-09-2006, 10:24 AM   #5
jlukins's Avatar
Default Re: (Rennen)
Thanks - but didn't work.
Attached is a (URL Link to) a JPG of my heater console.
Does your solution work for this model?
http://www.q5systems.com/temp/pb090002.jpg
Old 11-09-2006, 10:26 AM   #6
Sanji
toyomatt84's Avatar
This is in the OLD FAQ's:
Quote:
Originally Posted by toyomatt84
<FONT SIZE="4">DIY: Turn Off Automatic A/C Turn-On</FONT>
What you will need: Two Fingers
Time Needed: 10 seconds.
Annoyed with how you can't turn off the A/C when you turn to defog? Here's the override (realize that A/C expediates the defog process).
These steps are taken from a discussion thread on 2k1civic.com
1. Turn Car Off
2. Turn Temperature **** To Full Blue (All the way to the left - Counter-Clock Wise)
3. Turn Vent **** To Off (All the way to the left - Counter-Clock Wise)
4. Hold Down Air Recirculation Button As Well As A/C Button
5. Keep Both Buttons Depressed and Start Car
6. Keep Both Buttons Depressed for 7 Seconds
7. *AC LIGHT SHOULD BLINK*
You will now have control of your A/C regardless of what setting you are in, to revert back, simply repeat the procedue.
~Credit goes to: Ghosty's Tutorial.
( http://madstatic.com/2k1civic/diy/acdisable/ )
toyomatt84 is offline   Reply With Quote
Old 11-09-2006, 10:38 AM   #7
jlukins's Avatar
Default Re: (toyomatt84)
That did it - it worked !!!!!
Thanks for your help.
Old 11-09-2006, 11:06 AM   #8
fventura03's Avatar
i dont think it changes anything, i did it, but it still acted the same...
fventura03 is offline   Reply With Quote
1998 Honda Accord - Vent and Defrost Problems mmarquez661 Honda Accord (1990 - 2002) 1 11-08-2014 06:46 AM
Defroster Problem Civic082382 Tech / Misc 1 07-29-2013 09:16 PM
No power to A/C, Recirculation, Rear Defrost Buttons bradleyL22 Acura RSX DC5 & Honda Civic EP3 3 11-01-2012 11:10 PM
How To: Make your civic defrosters BETTER? mikehawkBUiLT Honda Civic / Del Sol (1992 - 2000) 22 01-08-2005 07:22 PM
civic question Matty Honda Civic / Del Sol (1992 - 2000) 5 11-24-2003 01:07 AM
Tags
2000, 2002, ac, air, button, car, civic, conditioning, console, defrost, heatar, heater, honda, light, lx, press, stays, turn, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
