2001 Honda Civic Overheating - Honda-Tech
Old 03-08-2009, 06:40 PM   #1
New User
Default 2001 Honda Civic Overheating
I need HELP!!! I have a 2001 Honda Civic EX and its Overheating....I checked the hoses and I replaced the radiator cap and its still getting HOT. I did notice that the radiator fan is not turning on, does anyone know what temp it comes on and if I should hear it come on. Someone told me that the relay switches go out, is this TRUE ???? I dont want to spend money on a new radiator if I dont have too...Does anyone have answers for me... Please HELP its my only mode of Transportation........
JOSIE is offline   Reply With Quote
Old 03-08-2009, 06:45 PM   #2
skipbarber's Avatar
Default Re: 2001 Honda Civic Overheating
im assuming you checked the coolant level?
skipbarber is offline   Reply With Quote
Old 03-08-2009, 06:51 PM   #3
New User
Yes, I checked the coolant level in both the radiator and reservior. When I turned my car off, the coolant was bubbling in the reservior.
Old 03-08-2009, 07:02 PM   #4
skipbarber's Avatar
have you ever replaced the thermostat?
Old 03-08-2009, 07:09 PM   #5
New User
No, would that cause the fan not to turn on?
Old 03-08-2009, 07:18 PM   #6
katzenjammer84's Avatar
If the thermostat isn't opening, then yes, the fans will not kick on.
katzenjammer84 is offline   Reply With Quote
d16y8 swap into 91 Civic - Overheating slightly the rook Honda Civic / Del Sol (1992 - 2000) 14 12-30-2015 02:17 PM
2000 honda civic overheated now shaking bad NicoleA Honda Civic / Del Sol (1992 - 2000) 5 12-10-2015 12:46 PM
92-95 Civic Radiator Fan "Always On" Wiring (Ignition) Asmar Honda Civic / Del Sol (1992 - 2000) 2 08-04-2013 01:36 PM
92 civic having radiator problems paintballa408 Honda Civic / Del Sol (1992 - 2000) 2 05-15-2011 10:53 PM
overheating problems grom Honda Civic / Del Sol (1992 - 2000) 5 08-30-2006 09:21 AM
Tags
04, 2000, 2001, 2005, bubbling, civic, coolant, em2, honda, overheat, overheating, overheats, reason, reasons, resivior
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
