Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic LX engine noise
Old 01-20-2011, 07:08 PM
Inextricabledrvr's Avatar
Default 2001 Honda Civic LX engine noise
I am trying to figure out for my little brother where this noise is coming from? It sounds like something is rubbing/knocking. Anyone have any input? I posted a video below for everyone to hear. :/
Old 01-20-2011, 08:48 PM
Plead da Fif
It Wasn't Me's Avatar
Default Re: 2001 Honda Civic LX engine noise
A. Your link doesn't work. When I click it, I get this.
.. but I found the video in your photobucket stuff.
B. It would help if there were some light in the video, so we could tell where you're pointing the video camera in the engine bay, but there isn't, so we can't. All I can make out is a little bit of the valve cover, and the A/C line.
Would you mind making a better video? During the day, or with a flashlight, or .. something .. so we can see.
Maybe you'll luck out someone else has experienced this exact problem and can tell you what it was. Whatever it is doesn't sound good.
Old 01-20-2011, 09:24 PM
Sorry about the lack of lighting. I will post a better video with lighting sometime tomorrow. In the meantime, hopefully someone can chime in on what this may be? It sounds really bad. I couldn't tell where the sound was coming from so, I went from one side of the engine bay to the other side.
Old 01-20-2011, 09:43 PM
Here's some info on the car...
2001 Honda Civic LX coupe 5 speed
1) 113K miles
2) Timing belt never been replaced (Water pump, belts etc)
3) Fluids regularly changed at proper intervals
4) Valve adjustment never been done
Can anyone distinguish what problem this may be by just listening to it?
3)
Plead da Fif
It happens.
You should consider buying one of these things.
It's a "mechanic's stethascope" and comes in handy for pinpointing noise origins. There are many different manufacturers, styles, and prices. Many of them are $20 or less. It's well-worth buying.
Old 01-20-2011, 09:49 PM
Will definitely have to pick one of those up.
Old 01-21-2011, 08:21 AM
Updated video with better picture.
Old 01-21-2011, 09:59 AM
honda.lioness's Avatar
1) 113K miles
The timing belt on your Civic is due every 7 years or 110k miles, whichever comes first. If the timing belt fails, the chances of irreparable engine damage are pretty good.
Change the timing belt, combined a/c and alternator belt, power steering belt, water pump, valve cover gasket, front crank seal and front cam seal.
Valve lash should be checked, but it is not common for it to go out of spec. I did not play the video.
I have successfully used a couple feet of 3/8" or so tygon tubing for narrowing down the source of odd sounds on my car. Though what "It Wasn't Me" suggests is better.
Old 01-21-2011, 10:08 AM
Plead da Fif
1) 113K miles
Timing belt and water pump need to be change, and in the process of doing them, you'll likely find where the noise is coming from. It sounds like it's coming from the driver's side of the engine bay, but even with good light it's hard to definitively say what is making the noise.
The valve clearances should also be checked. It's due.
Because it's a video, and not an in-person inspection, it really does make it more difficult to determine the source. In-person, there's more depth to what you're able to hear vs. the flat, cluttered together sounds of a video.
This will help with the work involved.
Timing Belt / Coolant Flush / Water Pump: Link
Valve Clearance Adjustment: Link
They're from the FAQ's
Old 01-21-2011, 10:11 AM
Plead da Fif
LOL! I've use garden hose for the same thing.
Old 01-21-2011, 10:37 AM
Thanks guys for your input and advice! I will inform my brother that he needs all this done.
Old 01-21-2011, 03:12 PM
So, he went to the local Honda dealer and he bought all the necessary parts. He spent about $160 for everything. (Timing belt, water pump, both seals, and valve cover gasket) He is planning on getting the other belts later. Not too bad for all original Honda parts.
Old 01-21-2011, 03:31 PM
lordhelmet1584's Avatar
What happens when you give it a bit of gas?
Old 01-21-2011, 04:13 PM
It sounds like it goes away when driving. The noise is mainly heard during idle. :/
Old 01-21-2011, 04:46 PM
Plead da Fif
The sound is probably just being drowned-out by road and engine noise while driving.
Hopefully it's something simple .. like bad alternator bearings or A/C compressor clutch components. (not saying that's what it is, just that they'd be easy to fix if they were the culprit.)
Old 01-21-2011, 08:14 PM
I was saying give it a bit of gas while stationary. Take your exhaust manifold off and shake it. Mine sounds a lot like that because there is a chunk of catalyst rattling in the converter.
Old 01-22-2011, 08:09 AM
I tried it stationary and the sound disappears when I rev it up. Once again it only happens during idle. Possible bad cat?
Old 01-22-2011, 08:57 AM
Plead da Fif
Anything's possible.
Have you been working on the car alone, or is someone helping?
My catalytic converter's heat shield used to rattle at a certain RPM, but it didn't sound like that. I ended up taking the whole thing off. (the heat shield, not the cat)
Have someone poke their head under the car while you press-and-release the throttle. If it's exhaust related, it should be really easy to tell.
Old 01-24-2011, 06:35 PM
He just got his Full timing belt over the weekend by a good friend of mine. He told me that the alternator bearings are shot and that's making the noise. :/
Old 01-24-2011, 10:30 PM
Plead da Fif
Ah-ha!! I thought that would probably be the culprit.
You can replace those bearings, btw. You don't have to buy a new alternator.
Old 01-25-2011, 06:13 AM
Seriously? That would save him alot of money. Is it a difficult process?
Old 01-25-2011, 09:51 AM
Plead da Fif
It's not difficult, but you'll need a heat-gun at least. You'll need to heat the rear bearing seat until it's 130-140 degrees, then separate the two halves of the housing. Once it's apart, inspect the rotor shaft and bearing journal for damage. If it's damaged, replace the alternator. Jaw pullers will help with removing the rear bearing and pushing the rotor shaft out, but probably won't be 100% necessary.
Old 01-31-2011, 07:40 PM
theineffable's Avatar
can you describe the sound better?
i've had a quiet ticking sound on my car since the car was near new and it only happens on a cold start then goes away after a few minutes. it also goes away if rpm changes.
i've already adjusted the valve clearance twice but the problem didn't go away.
now i think it might be a bad bearing somewhere. i know if i rev the engine slightly, the noise disappears for a moment. i also know bad bearings can make noises at certain resonant frequencies.
i'm hoping it's just bad alternator bearings. i would hate for it to be the timing belt tensioner pulley because i've already replaced the timing belt + water pump recently.
Maelong
12-19-2015 12:05 AM
OFCRPLZ
Honda S2000
01-09-2014 07:38 AM
dwills898
08-12-2012 05:13 PM
wgbm92
05-07-2012 11:40 PM
del sol1658
16
08-21-2006 11:27 AM
Quick Reply: 2001 Honda Civic LX engine noise
