01 Civic EX Wont Start... Electrical Issues I beleive... Need HELP!!! - Honda-Tech
Old 03-18-2012, 04:55 PM   #1
DK4200's Avatar
Icon2 01 Civic EX Wont Start... Electrical Issues I beleive... Need HELP!!!
I have a 2001 Honda Civic EX with 251,200 miles (bone stock) and the other day I was driving and the heat shield on the front exhaust manifold broke off and set off a CEL and Battery light. I ran the codes and got the following...
P0141 Oxygen Sensor Heater Circuit Bank 1 Sensor 2
P0135 Oxygen Sensor Heater Circuit Bank 1 Sensor 1
P1298 Electrical Load Detector (ELD) Voltage High
P0500 Vehicle Speed Sensor
After a day of driving it I went out to start it and it didn't start. I jumped it and ran fine but then died a few mins later. I noticed my dash lights, tachometer, speedometer and radio all shut off then the car died. I replaced the alternator and didn't seem to help. I replaced the battery and it fired right up I drove it to work about 8 miles away and on the way home when i hit my brakes my radio died and dash died again. My Battery light is off now but CEL is still on obviously. I addition to replacing the battery and alternator I replaced the 3 ground wires with 4 gauge wire but didn't help either. I only replaced them cause i had the supplies and the old ones were in rough shape.
I'm running out of ideas and thought id reach out to my fellow Honda-tech members for help. Any info or suggestions would be greatly appreciated
Dave
DK4200 is offline   Reply With Quote
Old 03-18-2012, 05:05 PM   #2
Pothole987's Avatar
Default Re: 01 Civic EX Wont Start... Electrical Issues I beleive... Need HELP!!!
Have you tried getting the new codes?
I'd check for loose connections on the battery terminals.
Pothole987 is offline   Reply With Quote
Old 03-19-2012, 05:47 AM   #3
DK4200's Avatar
I havent tried getting the new codes because i cant drive it anywhere without it dieing after 2 mins of driving. Battery terminals are nice and tight...
Old 04-21-2013, 05:58 PM   #4
i have a 96 civic ex starts an runs but i have the same codes + some. it just started 2 hours ago
p0500 vehicle speed sensor a . i changed it an still doesn't work
p1298 electrical load detector (ELD) voltage high
p0135 O2 sensor heater bank 1 sensor 1
po141 O2 sensor circuit bank 1 sensor 2
po420 catalyst system efficiency below threshold bank 1
po301 cylinder 1 misfire detected
po302 cylinder 2 misfire detected
p1300 no dtc definition found ..
darkside485 is offline   Reply With Quote
ECU AND ABS CODES HERE! Rory Breaker Acura Integra 105 09-29-2016 03:14 PM
[FAQ] ECU Codes for everyone JDMlyfestyle Honda Civic / Del Sol (1992 - 2000) 581 03-30-2015 11:07 AM
Short in wiring harness???? Spitz911 Honda Civic / Del Sol (1992 - 2000) 2 04-08-2014 05:12 PM
99 Civic EX - CEL code 20 DZO Honda Civic / Del Sol (1992 - 2000) 11 05-16-2012 11:49 PM
Help with Check Engine Codes bryan0 Honda Accord (1990 - 2002) 8 08-11-2008 05:40 PM
Tags
01, 2001, battery, brakes, car, civic, electrical, hit, honda, light, po500, problems, speedo, start, tachometer, wont, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
