Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Piston movement in block normal?
Old 03-12-2012, 06:19 PM
EK9
Dc4LsTeG's Avatar
Default Piston movement in block normal?
I have an 01 civic ex w/ d17a2. I pulled off the head and I noticed that the pistons have a lot of movement in them and I was jw if it was normal never seen it on my other engines.
Here's the video if you can even tell or see the pistons moving
TIA
Old 03-12-2012, 06:26 PM
Sanji
toyomatt84's Avatar
Default Re: Piston movement in block normal?
Have you done a compression test? If not, I'd recommend it.
Old 03-12-2012, 07:04 PM
lazlong's Avatar
^^ Agree.
How much is a lot? They'll move a little, like 100ths of an inch. Why did you have to pull the head? Did you overheat it and ruin the rings too?
Old 03-12-2012, 07:05 PM
EK9
Dc4LsTeG's Avatar
I didnt I know I should've done a compression and leakdown test before I pulled the head. I thought it was only gonna be the headgasket but once I took a look at the pistons I'm kind of worried
Old 03-12-2012, 07:11 PM
EK9
Dc4LsTeG's Avatar
Originally Posted by lazlong
^^ Agree.
I can push one of them to like each side of the cylinder wall without effort.it almost looks like the 3rd cylinder is out of round but I can't be sure till I get a bore gauge with the way the piston looks compared to the cylinder
Yes pulled the head cuz of overheating(bad headgasket)
If I fried the rings their would've been a lot of smoke right? It wasn't smoking at all
Old 03-12-2012, 07:16 PM
lazlong's Avatar
Video link isn't working.
Man, that sucks if it's a goner. The one ray of sunshine is that these engines are super cheap right now. There all over the local CL for $300-500 with about 100K. Or you can find a decent price here: http://www.car-part.com/
EDIT: Is the block warped?
Old 03-12-2012, 07:30 PM
EK9
Dc4LsTeG's Avatar
Damn photobucket. Let me see if I can fix the video.
Not sure if the block is warped didn't have the time to take a strait edge to it, it got dark to fast
Old 03-12-2012, 07:33 PM
EK9
Dc4LsTeG's Avatar
And if its a gonner I might just rebuild it. I'd rather spend the money on that then buying a used 100k engine and taking my chances with it. The car only has 108k on it. And since I got it its been nothing but problems. I hate these 01-03 civics sorry ill stick to my ctr lol
Old 03-12-2012, 07:43 PM
lazlong's Avatar
Good deal. You'll save some serious change rebuilding it. Maybe time to think about upgraded internals and a turbo. Or maybe it's time to think about a swap.
Yeah, much rather have my '91 back. Tired of fixing suspension problems every 50K miles and constantly replacing rubber.
Old 03-12-2012, 07:51 PM
EK9
Dc4LsTeG's Avatar
Lol na no upgraded internals or turbo its an auto...its just my dd to go to school. My ctr is fully built b18c5 turbothats my fast car
Old 03-12-2012, 08:17 PM
Dioxine's Avatar
Anu piston movement that seems abnormal is a sign of depleted rings or out of round cylinders. If you dont care about blow by or anything then put it back together and drive it till it blows up. However if you do decide to rebuild which is what I would do it would use a bore guage or a telescoping guage and confirm that it was indeed only the rings and not the cylinder walls themselves.
Old 03-12-2012, 09:14 PM
EK9
Dc4LsTeG's Avatar
Well if it comes to rebuilding it ill be having it bored and honed so that will take care of the cylinders
Old 03-13-2012, 07:54 AM
EK9
Dc4LsTeG's Avatar
Any more input before I tear this motor apart?
Old 03-14-2012, 06:01 PM
EK9
Dc4LsTeG's Avatar
2kdrift
08-18-2015 06:51 PM
Spawne32
09-26-2010 10:45 AM
sirt_eg
04-08-2009 09:31 AM
PIFFSTAR
03-27-2006 03:43 PM
lude019
02-09-2003 11:20 PM
Quick Reply: Piston movement in block normal?
