Are spoon/vision mirrors for eg/dc/ek exactly the same but use different bases/backings
ok story - in full I am going to have some kevlar mirrors made & need to know if spoon / vision mirrors are identical between eg/dc/ek & just use different bases to attach to the different chassis door's?
can the bases or mirror internals be purchased separately anywhere?
Re: Are spoon/vision mirrors for eg/dc/ek exactly the same but use different bases/backings (6SPD_EK
If you really want to know!.. Vision manufactures the mirrors for both spoon and vision. The first gen mirror housings and base were made of abs plastic, the mirrors them selves were NOT blue tinted and they had a rubber lining that went around the actual mirror. The second gen mirrors are different, they now come with the same abs plastic base but have carbon fiber mirror housings. In addition the second gen mirrors are now a blue tint and do NOT have the rubber lining around the actual mirror.
The mirrors and mirror housing are the same across the different chassis. As far as the bases go, i believe that the EK, EG and DC2 have different ones because of the changes in the mounting pattern.
I could be incorrect regarding the bases, can someone confirm?
With respect to the bases and mirror internals, I am sure you can contact one of the companies that make the knock-off mirrors and ask for the contact info on the company that actually does the manufacturing. With a big enough order I am sure you can work out a deal with the manufacturer where you can order the bases and internals in bulk. However, if you are making only one, you are better off going on ebay and purchasing one set of the knock off mirrors and using the parts you need.
all your base are belong to us
JK seriously tho, some one help the man out...
Re: (NIKE SB'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIKE SB’d »</TD></TR><TR><TD CLASS="quote">From personal experience EG/EK/DC2/DC5 are all the exact same mirror w/ different plates. </TD></TR></TABLE>
Well its confirmed, each chassis has a different mounting plate.
chrisir19
12-25-2002 07:59 AM
Yellow Dragon
37
02-24-2002 06:41 PM
