SHARE YOUR STANCE - The guide to achieving that ideal setup...
#1001
Re: SHARE YOUR STANCE - The guide to achieving that ideal setup...
Wheels: CST Precedeo Demon Camber
Specs (i.e. size, width, offsets):front: 15x7, +0 rear: 15x7, +19
Tire specs: 195/45/15 Toyo Proxes T1R
Suspension setup: Ground Control Coilovers w/ extended top hats, Koni Yellows
Camber specs: Natural Camber. Dropped to preferred height, no camber adjustment but always adjust toe to factory specs. Really saves tires!
Jack Point Measurement (from ground):
Additional comments about your setup:Had to pull the front fenders are rolled flat and pulled a decent bit in the front and roll flat to fit tires properly. Rear is rolled flat.
Overall rating of your setup (1-10): 8.5. Ground Controls ride really nice at this ride height which I could never say same when I was 1 inch lower.
#1003
I"ve been great Jose, just very busy working and raising my 2 and 4 year old daughters. Hope you are good! Man I am outta touch, have no idea with what you have been up to Honda wise. A quick search showed you had that super, super dumped TSX. Man that ride looks sick! I always admired your taste and that you had the brass ***** and know how to drive at that ride height. It looks lower than your DAP RHD, is it? Either way, it's the sickness.
Take care brotha!
Take care brotha!
#1005
Take care brotha!
Take care brotha!
I've been good been wanting to try something new so I'm with a tsx now. it was slammed on some rpf1 but i since raised it since i want to start my RHD conversion on it.
#1006
bumping that thread from the dead
Wheels: LENSO BSX
Specs : 16x9 20+- with 5mm spacer all around
Tire specs: 205/45 Zeetex
Suspension setup: Raceland coilovers
Camber specs: (-3) front (-5) rear
Jack Point Measurement 1.9 inches
Additional comments about your setup: i like overall. for that low, ride is good. i was planning to fully need tuck the tyersand extra -2 camber....i wish i still have it
IMG_3356 by ph_ayman, on Flickr
IMG_3326 by ph_ayman, on Flickr
IMG_3331 by ph_ayman, on Flickr
Wheels: LENSO BSX
#1007
Wheels: American Racing
Specs (i.e. size, width, offsets): 16x7 ~15 (not sure of offset since wheels don't say and I have adapters 4x100 to 4x114.3)
Tire specs: 165/45 all around
Suspension setup: D2 "Super Low", 14k front and 8.5k rear
Camber specs: natural camber all around from dropping the car
Jack Point Measurement (from ground): No clue, but stock jack doesn't fit.
Additional comments about your setup: Rear suspension is maxed out, front was messed with preload to make it sit like the rear. It also has dampening adjusting. I've been through 3 different set ups, and so far this is the best one. For how low it sits it rides amazing. I'd recommend NOT messing with the preload, since it makes the ride bouncy. This is the reason I bought myself some front drop forks.
Overall rating of your setup (1-10): 9
#1009
I doubt it since the American Eagle Alloy Series 28's came in 15x8 and 15x10 (mine are 16x7), also the sides of the star on the ARE wheels are bigger than the AEA. The lip is also different because of the width difference.
#1010
Sanji
http://datsun510.com/photopost/data/...AREtype398.jpg
Its on the left hand side. And, you're correct, that's from an American Racing catalog in '91.
#1011
Funny dudes picking his *** in the pic...lmfao, helllll nawww, oh on page 16, grey JDM EK...middle pic....quick,,,, hurry,, look!
#1012
Wheels: XXR 002.5
Specs: 16x8 +20 offset
Tire specs: 205/40R16 all around
Suspension setup: H&R springs
Jack Point Measurement (from ground): No idea
Additional comments about your setup: zero rubbing with mild rear quarter roll
#1013
Wheels: Volk Te37 Sl Hyper Blue
Specs: 18x9.5 +22 offset
Tire specs: 245/40R18 all around
Suspension setup: BC Coilovers
Camber specs: Not sure
Additional comments about your setup: front and rear rolled and rears pulled quarters slightly so i could run the less amount of camber
#1014
Wheels: Klutch Bronze SL1
Specs (i.e. size, width, offsets): 15x8.5 +15 offset
Tire specs: 195/45/45 Federal Formoza!
Suspension setup: D2 RS 36-way blox, bwr camber kits
Camber specs: unknown
Jack Point Measurement (from ground): somewhere around 2 inches
Limited Driveability, not the best set up for street but it looks sick. driven very little
mainly shows for now. but I thought I would share.
Overall rating of your setup (1-10): 7.5
#1015
1998 Acura Integra 4 Door
Wheels: Work Meister CR-01
Specs (i.e. size, width, offsets): 16x8 +22 A-Disk Front 16x8 +32 O-Disk Rear (57mm Rim Depth)
Tire specs: 195/45/16 Yokohama S-Drive
Suspension setup: Buddy Club N+ (+2 hard for dampening)
Camber specs: 1.5 Front 1 Rear
Additional comments about your setup: Front and rear fenders are rolled just enough to flatten the "fender lip". Ride height is just low enough so the front wheels have a little less than a centimeter of gap and rear tires are covered by about 0.5 cm when looking at it from the side. Overall riding at this height with the current dampening setting is a fairly smooth ride and no issues with rubbing. I would run lower offset wheels or go lower, but it is my daily so I didn't want to run too much camber and still be able to drive over most speed bumps.
#1016
2013 Acura ILX
Weds Kranze Borphes
18x8 +45 all around
Nitto Neo Gen II 215/40
ISC Sport Coilovers 12k front 8k rear
Camber isnt exact but around -3 rear -1 front
All fender tabs rolled. Very slight pull in the front. 25mm Garageline spacers all around.
Work VS-MX
18x8 +35 all around
Everything else same as with the Weds.
Works sitting in the garage right now awaiting a rebuild. Currently sporting the Weds for daily driving.
Weds Kranze Borphes
18x8 +45 all around
Work VS-MX
18x8 +35 all around
#1017
O.G. triple O.G.
1997 Honda Del Sol Si
Wheels: Enkei 92
Specs (i.e. size, width, offsets): 15x8 ET25
Tire specs: 205/50/15 Hankook Ventus V2
Suspension setup: Progress CS-II coilovers, Wicked Tuning camber kits (F/R)
Camber specs: N/A
Jack Point Measurement (from ground): 4"
Additional comments about your setup: Still have plenty of threads left on the coilovers. Current height works well since I drive the car to/from work daily. Rear fenders rolled for maximum tire clearance.
Wheels: Enkei 92
Camber specs: N/A
#1019
Wheels: Kosie K1 TS
Specs (i.e. size, width, offsets): 15x7", +38 offset
Tire specs: 205/50-15 Bridgestone Potenza Re-11's
Suspension setup: Eibach Sportline Springs and pro Dampers
Camber specs: -.75* in the front, -1.5* in the rear
Additional comments about your setup: Had to roll the fenders a decent amount in the rear. The fronts rolled themselves on the tires lol. Rubs the fenderliners pretty good. big holes in mine and also rubs at full lock as well. the ride is SUPERB though and the handling is great for DD'ing. i'm gonna be switchin to 375/350 GC's in a few months though.
Former User
10-01-2012 11:06 AM
