polishing valve cover - Honda-Tech
Old 09-21-2001, 08:52 PM   #1
New User
Default polishing valve cover
started polishing it but dont know how to get between the HONDA lettering w/ sandpaper. by the way i am starting with 150fine then 220 extra fine then 400 some one said i had to wet the paper? i dont know, but i cant get all the grime that dripped down from the plug holes. oh and i got some generic multy meytal polosh too, anything else work better? or any pics?
clean is offline   Reply With Quote
Old 09-22-2001, 01:55 PM   #2
JimmieD's Avatar
Default Re: polishing valve cover (clean)
you should strip it, then sand it with a soap/ water mix with a really high grit paper. I believe you should end up using a 1500 or 2000 paper in the end. That is what i have found as far as polishing.
JimmieD is offline   Reply With Quote
Old 09-22-2001, 02:15 PM   #3
JG Luder's Avatar
Default Re: polishing valve cover (lsinteg)
I'm trying to think of the stuff we use...
wait....
JG Luder is offline   Reply With Quote
Old 09-22-2001, 02:17 PM   #4
JG Luder's Avatar
Default Re: polishing valve cover (JG Luder)
ah ha! I remember now! Aircraft remover, yes it actually says that, (WalMart)... garanteed to rid your yard of 747s and get the paint off your valve cover. Only use 800-1500, and even 2000 if you have patience. Lower grit than that and you'll scar the metal.
A polishing wheel with some good hard compound is a must. Sears can help you out in this area.
Old 09-23-2001, 11:25 AM   #5
PROFILES2000's Avatar
i just used the aircraft remover today and wow i was impressed
PROFILES2000 is offline   Reply With Quote
Wheel Polishing shop Sac or Bay Area Token Blk Guy Northern California 21 04-23-2012 09:17 PM
FS(PA):16x7 +20 konig remembers 4x100 forumjw Wheels 8 12-16-2009 02:51 PM
polishing the tops and sides of pistons? DC5ftmfw Tech / Misc 6 09-22-2006 01:08 AM
Refurbishing Swirlies! PhiLG Honda / Acura 4 07-10-2004 02:56 PM
can i get my rims polished? EKtypeRhaTcH Honda Civic / Del Sol (1992 - 2000) 4 04-29-2004 02:17 AM
Tags
cover, polishing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
