my 88 hatch thread!
my 88 hatch thread!
Just want to post some pics of my 88 dx hatch. I've had for 4 years. This hatch has been through a lot. Have installed a lot of different parts but overall look is clean. No Haters please. Here are some specs
Interior:
-08 S2000 seats
-05 RSX type s black leather rear seats
-03 RSX cluster
-OEM USDM Acura Type R accessory shift **** (bought from dealer, made by DC Sports as an aftermarket accessory for USDM ITR)
-OEM JDM ITR Shift Boot
-Power windows
-Autometer Tach (got before I installed cluster with a tach)
-Interior is complete, no missing parts, dash and panels and cargo cover oem
-Rear speaker pods
Exterior:
-JDM ZC 90-91 headlights (amber city lights drilled into headlights)
-EDM rear foglights
-89 usdm prelude fog lights
-JDM side markers
-91 DA front lip
-USDM OEM bumpers and moldings
-88 Sedan mudguards
-2007 Toyota barceolona Red paint job
Wheels/Brakes/Suspension:
-Koni Yellows
-No name coilovers
-15 inch White Buddy Club P1
-Drilled and slotted rotors on all 4 wheels
-DA complete brake system (all 4 wheels, spindles, calipers, rear disc conversion, brake booster, master cylinder, and prop valve)
Engine:
-Stock Gen2 JDM b16a
- No name header
- Autozone Intake (came with dpfi motor and too lazy to buy a legit one)
-Wire Tuck
-Battery and fusebox relocated
-HONDATA S300
When I first got her
First transformation
A little more
Had it like this for 1.5 years
Painted Finally
Old pics
After I rear ended a suv
And now
Interior:
-08 S2000 seats
-03 RSX cluster
-Power windows
-Rear speaker pods
Exterior:
-EDM rear foglights
-JDM side markers
-91 DA front lip
-88 Sedan mudguards
-Koni Yellows
-No name coilovers
Engine:
- No name header
-Wire Tuck
-HONDATA S300
A little more
Painted Finally
Old pics
And now
Re: my 88 hatch thread!
At first wasn't really feeling the gauges but they look great lit up and definitely feeling the s2k/RSX hybrid interior. How much fabrication did you have to do for the RSX rears to go in?
Real easy you guys. For the s2k seats to go in, I actually welded my own custome bracket and then weldelded to s2k rails, so seats them self were not modified. The rsx in the back was also cake. The rears snap right into place with the stock latches on the side. But you must have the rear cargo cover for them to work, because that is what helps hold them into place. The bottom part of the seats is the issue. The seats are longer in width (front to back) and shorther in lenght ( driver side to passenger side), so first u cut foam underneath seat so that the sit flush and clear your gas hose where you pump gas, and then you just insert seat belt. Latches which helps hold seats in place. If you notice on one of the pics of rear seats, you can see a bit of red on the side. I was going to lay down black carpet to cover it up, but haven't gotten to it
