Maximum Tire and Wheel Fitment Thread
Old 04-02-2009, 03:39 PM
be18see1's Avatar
Default Maximum Tire and Wheel Fitment Thread
After seeing this thread on 240sx.org, I want one for us. By maximum fitment, I mean width. That being said, make it rain.
Old 04-02-2009, 07:01 PM
beevo.'s Avatar
Default Re: Maximum Tire and Wheel Fitment Thread
It is raining. That's all it's done here for the past week.
Old 04-02-2009, 07:08 PM
ErrDizzle's Avatar
205 and under need not apply here....
i got some 245s for this thread
Old 04-02-2009, 07:13 PM
SlammedDC2teg's Avatar
Post some pics. I want to see some reverse staggered wheels with 245s.
Old 04-02-2009, 07:21 PM
Sanji
toyomatt84's Avatar
It's weak compared to most RWD setups, but I figured I'd give this thread a starting point.
SSR Schumachers
16x8 +37
15mm spacer on front wheels to clear brake calipers
Camber:
Front: -3 degrees
Rear: -1 degree
Tires:
225/50/16 Dunlop Direzza Z1 Star Spec
Old 04-02-2009, 08:52 PM
denverjdm's Avatar
i make it rain...
this is my old daily
1992 integra rhd, these ended up being WAY to big, riken mesh
old daily ... sport max 002's i spent hours and hours trying to make these fit
Old 04-02-2009, 08:56 PM
The Boot
Smokinsax's Avatar
this should be a good read.
Old 04-02-2009, 10:59 PM
Sanji
toyomatt84's Avatar
Tire stretch? Weak. You could have easily fit those tires on a narrower wheel, first of all. Secondly, if you had bought some wheels that actually fit your car properly, you wouldn't have had any fitment issues with that wheel width/tire combination. This isn't the low offset thread. We've already got one of those. Come back when you get something beefier to post up.
Old 04-03-2009, 02:55 AM
chargeR's Avatar
275/40 on 9.5 front and 245/40 on 8.5 rear Hoosier R6s (rears not fitted in this pic they are 235/45 AD07).
Old 04-03-2009, 03:04 AM
Lasty K's Avatar
Woo wee 275
Old 04-03-2009, 09:31 AM
HRD PKR
B16B_coupe's Avatar
hey matt do you have any side shots of how fat the tire is? Maybe i could fit em on the civic
Old 04-03-2009, 09:59 AM
Sanji
toyomatt84's Avatar
I could do you one better, bud. I'll have my floor jack with me down at IA. You can swap rears with me, down there. See if they rub on full lock and what not. They'll be on a pair of 16x7 +35's.
Old 04-03-2009, 10:18 AM
HRD PKR
B16B_coupe's Avatar
Sweet I plan to track my rig again! LEt me try em out J/k
Yeah my 215/45s rub at full lock on the mugens but they're +42 i believe. Maybe a 5-10mm wheel spacer?
Old 04-03-2009, 10:42 AM
denverjdm's Avatar
i never said anything about tire stretching, i was talking about modifying my fenders to make a 9 inch wide wheel with huge tires fit on my car
Old 04-03-2009, 10:45 AM
HRD PKR
B16B_coupe's Avatar
Whats your tire size?
Old 04-03-2009, 11:05 AM
denverjdm's Avatar
i wanna say 225 or 235 ill check when i get off work.
Old 04-03-2009, 12:04 PM
be18see1's Avatar
That RSX is crazy! What did you have to do so that you could run a 275 series in the front and still turn?
Old 04-03-2009, 12:13 PM
Sanji
toyomatt84's Avatar
Spacers would work, but anything over 7mm would require extended studs. As much as I like your Mugens, I'd recommend getting a wider/better offset for bigger tires.
You don't have to say anything about tire stretching. You can see it in the pictures. If they are 225 - 235's, you could have put them on a 7.5" wide wheel for better tire fitment. With those 9" wide wheels, proper fitment is around 255 - 265. What you have now is perfect for the low offset thread, but those tires are just too weak for this thread.
Old 04-03-2009, 12:24 PM
BigFootPS's Avatar
more pix
Old 04-03-2009, 02:49 PM
HRD PKR
B16B_coupe's Avatar
Yeah man, i'm ordering some 16x7 +33's I think they will be perfect! I can't wait to order them. I know they prob wont be here by IA though
Old 04-03-2009, 02:55 PM
Nate047's Avatar
hey Matt you've got a K20 in there yea?? can we get some more pix? looks great
Old 04-03-2009, 03:05 PM
Sanji
toyomatt84's Avatar
K24, bud. There are some pictures floating around from the IA meet back in July... but currently the car is under the knife again. It'll be ready for IA this year, though.
Old 04-03-2009, 03:14 PM
chargeR's Avatar
My street/hardparking setup. 255/40 and 235/45 Advan AD07s:
Well I can still turn a bit, but I won't be doing any U turns. The tyres rub on the fenderliners and then probably hit steel before I get close to full lock. Doesn't matter for track use.
BTW its an Integra :p.
Old 04-03-2009, 03:23 PM
what gsr's Avatar
fraking thank you for that picture.. so insanely sick!
Old 04-03-2009, 03:59 PM
Sanji
toyomatt84's Avatar
Still one of the best examples of proper tire fitment, though.
Quick Reply: Maximum Tire and Wheel Fitment Thread
