Difference between PPG paint and Dupont paint?
I went to body shop today and he said that they use Dupont paint.
I asked is PPG better? he said no, it just costs a little bit more, and if i want, i can get PPG paint for a little more money.
Difference?
Difference?
Re: Difference between PPG paint and Dupont paint? (Jawad)
Both brands are the best, top of the line. I used PPG paint when I painted my car, Dupont is just as good, you cant tell the difference in either case.
Re: Difference between PPG paint and Dupont paint? (Slow-R)
I use Dupont in the body shop I work at, its all in what you like, I just have always worked with Dupont but I hear PPG is just the same. The big difference I believe is just in primers... hopefully that will help alittle
My car was sprayed with dupont, my old car with PPG, can't really tell any difference, pleased with both.
New User
you better make sure to use the oil based paint, which are being used by Japanese and German. not to mention that the US uses the water based paint, i don't know exact reason but i guess it's cheaper than oil based paint.
when comparing my Amerian built honda(water based paint) to my mom's Japanese built honda(oil based honda), the color is different.
the oil based paint gives deeper paint color.
$.02
$.02
Re: Difference between PPG paint and Dupont paint? (vtec94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94 »</TD></TR><TR><TD CLASS="quote">you better make sure to use the oil based paint, which are being used by Japanese and German. not to mention that the US uses the water based paint, i don't know exact reason but i guess it's cheaper than oil based paint.
$.02</TD></TR></TABLE>
Am not sure about this for cars, but i know u are not allowed to use oil based paint in houses
its law i believe
its law i believe
Re: Difference between PPG paint and Dupont paint? (jz)
I just finished spraying my car with PPG and I had problems with using sealer and high build primer. It would react around the edges where I used the sealer and primer, and both were PPG products. I ended up doing the whole car in sealer first, then color over that.
I'd use dupont next time.
jwicecold
Paint and Body
30
11-09-2011 10:38 PM
