D-Rob's S2000 Cluster-Into-'98-Civic-Coupe Project *Pix0rs* - Page 9 - Honda-Tech
Old 11-25-2008, 03:38 PM   #201
hey bro
i completed my s2k ap1 cluster a couple months ago it works perfect i used a motorcycle convertor box for my speed convertor and it has top speed memory and all that.
i aslo changed my redline on mine it looks good.
you have done a great job on yours!
i would love to make my bezel like yours could you assist me? as in EVERYTHING i need to do this bezel right.
major props on getting the bezel situation figured out! it has stomped everyone.
i also bought the start button when i got the cluster any pointers on hooking it up me and couple my car buddys are going to put mine in this week.
i was going to just fiber glass one a bezel but yours looks much easier and very oem!
ill send your pics of mine whenever you contact me.
please
pm me on here
my emai is yeahsirb16@yahoo.com
txt- 615 957-9915
yeahsirb16 is offline   Reply With Quote
Old 01-16-2009, 08:37 AM   #202
InTheZoneAC's Avatar
Default Re: D-Rob's S2000 Cluster-Into-'98-Civic-Coupe Project *Pix0rs*
I have been looking around for someone to do a custom bezel/s2k cluster prewiring and all that good stuff for my 00 civic.
I will pay for this lol
InTheZoneAC is offline   Reply With Quote
Old 01-16-2009, 10:00 AM   #203
Seedc2's Avatar
stunning, it sure does look oem. job well done
Seedc2 is offline   Reply With Quote
Old 07-07-2009, 06:36 AM   #204
plummo_vtec's Avatar
Quote:
Originally Posted by yeahsirb16 View Post
hey bro
please
pm me on here
txt- 615 957-9915
same goes for me too i would love to know how to so i can have a bash myself
plummo_vtec is offline   Reply With Quote
Old 11-29-2009, 01:34 PM   #205
ebp 99 si's Avatar
back from the dead..
i've been doing some research on doing this in my si, but i can't find a speedo converter anywhere
i just found this, would it work? http://www.dakotadigital.com/index.c...126/prd126.htm
i saw dscustoms.com doesn't work anymore, yeahsirb16, where did u get your motorcycle converter?
also d-rob, have you made anymore bezels? i can ship mine up to you, how much would it be?
ebp 99 si is offline   Reply With Quote
Old 11-29-2009, 02:59 PM   #206
lub
lub's Avatar
Default Re: (Brick Top)
Quote:
Originally Posted by D-Rob View Post
lol at the phone call...i love this install, i'm totally jealous!
lub is offline   Reply With Quote
Old 11-29-2009, 04:00 PM   #207
BoostKiller's Avatar
man i want a s2k cluster so bad now that video is sick
BoostKiller is offline   Reply With Quote
Old 11-30-2009, 08:07 AM   #208
EKtypeRhaTcH's Avatar
The Converter is called the Speedohealer.
EKtypeRhaTcH is offline   Reply With Quote
Old 11-30-2009, 09:25 AM   #209
vinced87ek's Avatar
good job man. u should just make a bunch o harnesses and bezels and flip em to make some $$
vinced87ek is offline   Reply With Quote
Old 11-30-2009, 10:24 AM   #210
ebp 99 si's Avatar
Quote:
cool, thanks man
but..what harness would i get when i order it?
Old 11-30-2009, 11:47 AM   #211
ChadB's Avatar
the new hype!
ChadB is offline   Reply With Quote
Old 04-14-2010, 12:05 AM   #212
jdmdb8r's Avatar
sick bezel...
jdmdb8r is offline   Reply With Quote
Old 09-08-2011, 02:26 AM   #213
Sorry to bump a rather old topic, but since this is one of the few completed cluster swaps, I am hoping this is the best place to post my problem/question.
To start off, I am driving with a fully functional AP1 cluster for almost a year now (including ECT, Speedohealer and acurate fuel-level indicator).
Here's my issue:
By now several forums have copied the same wiring scheme, and because of the 'copy paste' they all have the same instructions on how to connect the ABS control light.
Connector D: BLUE/RED <> BLUE/RED
I am sorry to say that they all have the wrong instructions if your car has ABS (like mine).
Or I overlooked something (which I doubt).
The ABS light goes off when connected to a ground, that's true. But the ABS wiring comming from the car isn't a ground an never becomes one. So if you Civic has ABS (like mine) connecting both wires results in a ABS light that's allways on
What I did was connecting it to a ground and the light stayed off, but yesterday my car was at a garage for it's yearly MOT/APK (or whatever you call the mandatory checkup of your car in your country).
The car got a 'not approved' stamp because it has ABS and the ABS light in the cluster is not showing when turning the ignitionkey in the first position.
So I removed the cluster from the dash and checked every possible option. I even try to 'fake' a functional ABS light by connecting it to the wiring of the oil pressure, since that one has the same characteristics (light on in first position and going of when the key is going to the second position and start the enigine).
All without any luck, since the light needs a (switched?) ground and not a switched +12v.
Since cars only have switched +12v and no switched ground, I opened the original cluster and found out that the OEM civic cluster has a seperate ABS module/light:
To make a long story short........
Should I use this module to get a functional ABS light or is there anyone out there driving a '96 Civic with a fully functional ABS light is his/her AP1 cluster?
Hope to hear a solution, because I can't believe I am the only one with this problem.
flits is offline   Reply With Quote
Old 12-27-2011, 07:46 PM   #214
wilson091's Avatar
sorry to bump an old thread, but after watching that quick video, i would love to have a s2k cluster and push start! props to you sir!
wilson091 is offline   Reply With Quote
Old 02-14-2017, 09:35 AM   #215
Default Re: (RDix)
After a vacation in Ocean City, MD this past weekend, I arrived at the shop, greeted by the finished product.
My father finished up the bezel while I was gone, and took a few pictures of the bezel after paint, as well as a comparison shot versus the stock once more.
First, painted flat black...
Then with a little Megiuar's to add some shine (BLING, to Ben) to the piece.
There you go. Fits/looks like it was put there from Honda.
- Derek
What did you use to make the bezel fit around the cluster?????
timothy.ej6 is offline   Reply With Quote
Old 02-16-2017, 05:16 PM   #216
JDMdoode's Avatar
Default Re: (RDix)
Quote:
The most recent post before yours was in 2011.... I believe you would have better luck creating your own thread in the appropriate section to ask for ideas and recommendations. Or PM the user.
JDMdoode is offline   Reply With Quote
Old 02-18-2017, 10:31 AM   #217
No Jodas
ShinsenTuner's Avatar
Derek's S2000 install has been the best ever done and still holds that crown.
LOL @ the new bezels they sell out there now. They look so booty.
ShinsenTuner is offline   Reply With Quote
Old 02-26-2017, 05:19 PM   #218
Parties with 2LEM1
Brice.Hayden's Avatar
Booty is good right?
Brice.Hayden is offline   Reply With Quote
Old 02-26-2017, 05:36 PM   #219
No Jodas
Yes Brice.
East Coast is the Right Coast - Let's try this again... D-Rob Group Threads 52582 03-09-2017 01:40 PM
FS/FT: The most complete AP1 cluster swap ever for an EK D-Rob Mid-Atlantic (Sales) 12 02-08-2011 04:01 AM
All Motor LSVTEC Build (ANOTHER!): D-Rob's Daddy's CR-X (Pics, included) D-Rob All Motor / Naturally Aspirated 290 05-14-2009 06:42 AM
The East Coast is the Right Coast D-Rob Honda / Acura 135 09-05-2007 04:21 PM
Friend's Integra GSR project - Couple of snaps! D-Rob Honda / Acura 22 03-22-2007 07:24 PM
Tags
98, civic, cluster, diy, ej8, ek, fit, honda, plugs, put, s2000, s2k, sale, speedometer, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
