4 to 5 lug adapters
#26
#27
Re: 4 to 5 lug adapters (brand0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brand0 »</TD></TR><TR><TD CLASS="quote">doesn't seem too safe to me..
so those allen bolts are the only things holding the wheels to the hub? how do you even torque those? those are the most retarded things ever.
#28
Re: 4 to 5 lug adapters (donut.)
i could see this working better on a vw because the the bolts go through the wheel into the spindle where as with a honda the bolts come out of the spindle and a nut is applied
#29
Re: 4 to 5 lug adapters (743 Stunna)
240 guys using those for awhile so i dont see whats not so safe about it...just torque it correctly and your good to go
#30
Re: 4 to 5 lug adapters (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii »</TD></TR><TR><TD CLASS="quote">240 guys using those for awhile so i dont see whats not so safe about it...just torque it correctly and your good to go</TD></TR></TABLE>
yea, some 240 by my school has em.. not the ones pictured in this thread, but they are hub adapters none the less.
#32
Re: 4 to 5 lug adapters (iBear)
no look at the design, there are 4 larger holes on the thicker part of the adapter that bolt to your stock hub with lug nuts, then there are 5 smaller holes that hold the second part of the adapter to the first part and that second part has the 5 lug
#33
Re: 4 to 5 lug adapters (OGegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OGegg »</TD></TR><TR><TD CLASS="quote">no look at the design, there are 4 larger holes on the thicker part of the adapter that bolt to your stock hub with lug nuts, then there are 5 smaller holes that hold the second part of the adapter to the first part and that second part has the 5 lug</TD></TR></TABLE>
exactly! so whats so bad about them?
#34
Kids try so hard these days to gain acceptance into the world that we call Honda-Tech.com.
What is so bad about four lug.
#35
Re: 4 to 5 lug adapters (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">Kids try so hard these days to gain acceptance into the world that we call Honda-Tech.com.
What is so bad about four lug. </TD></TR></TABLE>
nothing im rocking 4x114 all day
#37
because you still have five allen bolts that hold the thick and thin parts together. that should also be torqued to over 50 ft-lbs
#38
the only thing holding on your wheels are those allen screws that you can't torque to 80ft-lb's like you can with lugs. you'll strip the heads at 40 ft-lb's maybe less. not only that, look at the thread pitch on them. they dont look like they can take very much pressure on a hard turn.
do you guys even know what the purpose of having 5 lug is? its not for wheel selection.
keep in mind even if you do get these, you have to compensate by getting a high offset wheel +45 at the lowest which reduces your wheel selection. so basically, not only is it unsafe but its a waste of money lol
#39
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">Keep in mind even if you do get these, you have to compensate by getting a high offset wheel +45 at the lowest which reduces your wheel selection. so basically, not only is it unsafe but its a waste of money lol</TD></TR></TABLE>
Bingo
Bingo
#41
Re: 4 to 5 lug adapters (esoterEK..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. »</TD></TR><TR><TD CLASS="quote">i still dont understand how these things work.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howangseg »</TD></TR><TR><TD CLASS="quote">http://youtube.com/watch?v=vnwf2JWcgg8</TD></TR></TABLE>
#42
there has to be some issues with the adapters i mean why wouldnt it be more known? everyone would be swapping these apdapters the way i look at it you should just go with 4 or 5 lug and pay the extra dollars to protect your life and your investment
#44
Re: (howangseg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howangseg »</TD></TR><TR><TD CLASS="quote">http://youtube.com/watch?v=vnwf2JWcgg8 </TD></TR></TABLE>
damn noobs. the wheels came off because he was given lug nuts with the wrong taper and the stock wheel studs broke off as a result. he didnt even have any spacers.
#45
Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 »</TD></TR><TR><TD CLASS="quote">dont all the drifters use these? if they can go sideways with em, i'd like to think thats enough R&D for me</TD></TR></TABLE>
LOL NO
LOL NO
#46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">do you guys even know what the purpose of having 5 lug is? its not for wheel selection. </TD></TR></TABLE>
Remember where you're at man, this is app/cosm section.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">keep in mind even if you do get these, you have to compensate by getting a high offset wheel +45 at the lowest which reduces your wheel selection. so basically, not only is it unsafe but its a waste of money lol </TD></TR></TABLE>
Ding ding ding...nobody thinks of offsets, only size and lug. Look at how thick those adapters are, it should be common sense how high your offset would have to be to run them.
#47
Re: (ErrDizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ErrDizzle »</TD></TR><TR><TD CLASS="quote">Damn noobs. The wheels came off because he was given lug nuts with the wrong taper and the stock wheel studs broke off as a result. he didn't even have any spacers. </TD></TR></TABLE>
I know this...just thought it related real well with what might possibly happen. And it's always good for a chuckle.
#48
Re: 4 to 5 lug adapters (Thurman Merman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman »</TD></TR><TR><TD CLASS="quote">Ding ding ding...nobody thinks of offsets, only size and lug. Look at how thick those adapters are, it should be common sense how high your offset would have to be to run them.</TD></TR></TABLE>
the adapter looks to be at least 1 inch. so 1 inch is about 25.4 millimeters.
lowest offset i was able to run without rubbing was +33 but some of you are crazy with that.
take that 33 offset wheel and add 25.4mm and the lowest offset i'd be able to run with those adapters is, lets say 58 and up, good god! how many wheels with that kind of offset in 15 and 16" lmao
but hey, its your money lol
#49
Re: (gabebauman)
these look ALOT more promising then those 2 piece design, that 2 piece looks VERY unsafe, i would pick these over those any day. they bolt on with your lugs and thats it. no need to worry about those alan screws breaking
#50
Ladies and gentlemen we are floating in space...
Well, I think the point would be to use to OEM ITR wheels, which have a pretty high offset and, as shown, will fit.
