whistling noise from dashboard - Honda-Tech
Old 02-04-2013, 04:32 AM   #1
Default whistling noise from dashboard
hi there new to this , so bear with me
i have just bought a 2006 Honda accord s type well a few weeks ago
it has now developed a whistling noise from the dashboard while driving
i have turned off the climate control , but the whistle is still there?
it is not a continuous whistle just every now and then , but is bugging the hell out of me ? any ideas folks is this an airleak from heater?
also passenger side headlight has started misting up. have dried this out twice and is misted up again by morning? does this model have the air flow pipes at the back ? if i take the headlight off completely will it go back in exactly the same position or will they need adjusting?
hope you can help
ian
captainskip is offline   Reply With Quote
Old 02-27-2013, 10:24 PM   #2
emoze's Avatar
Default Re: whistling noise from dashboard
have same whistling noise in an '04 sedan - 25-40 mph
- started after windshield was replaced - that may be a clue
i have tried taping around the windshield but the noise is still there; also have tried removing the cabin filter
emoze is offline   Reply With Quote
Old 02-28-2013, 08:46 AM   #3
Sorry to hear about that, I have an 8th gen, but haven't had any whistling problems, nor have I heard about others having this problem.
TheTruth117 is offline   Reply With Quote
lighting fogging captainskip Lighting 3 02-16-2013 09:36 AM
what kinda intake whistles or what is causing it to whistle? CrazyRexBoy Acura Integra 25 12-03-2006 11:58 AM
whistling noise from the engine slow_redcivic Honda Civic / Del Sol (1992 - 2000) 6 09-03-2005 05:41 PM
TB whistling popngen Honda CRX / EF Civic (1988 - 1991) 4 06-29-2004 12:23 AM
Wierd whistling noise......help! Petah Honda Civic / Del Sol (1992 - 2000) 12 06-20-2002 09:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
