When to change timing belt on 2005 Accord? - Honda-Tech
Old 01-21-2008, 11:00 PM   #1
Two400's Avatar
Default When to change timing belt on 2005 Accord?
Hello. My radio is fixed. But I have no idea when the timing belt is supposed to be changed. I'm around 72,000. Is this something that is checked with an oil change? Or do you have to ask for it to be checked? Also whenever I do get it changed, how much does a new timing belt typically cost?
Two400 is offline   Reply With Quote
Old 01-22-2008, 08:09 AM   #2
JimBlake's Avatar
Default Re: When to change timing belt on 2005 Accord? (Two400)
What engine?
2005 Accord 4-cylinder has no belt. The timing chain doesn't get replaced on any kind of schedule.
2005 Accord V-6 timing belt is probably the same 90k interval as most of us are accustomed to. The maintenance schedule should be in your owner's manual package. Probably in the maintenance book, buried in the list of service schedules for the maintenance-minder.
JimBlake is offline   Reply With Quote
Old 01-22-2008, 05:10 PM   #3
HondaTechAV6's Avatar
it's been extended to 105k, hehe
HondaTechAV6 is offline   Reply With Quote
98 civic ex just changed belts and now idle is crazy freseray Honda Civic / Del Sol (1992 - 2000) 1 04-20-2011 09:50 PM
H22A Timing Belt Change Problems orangeaccord Honda Accord (1990 - 2002) 3 07-11-2009 04:05 PM
noise during acceleration after timing belt change chibiko Honda Accord (1990 - 2002) 16 02-06-2007 09:22 PM
TIMING BELT accordlover Honda Accord (1990 - 2002) 21 12-01-2005 07:43 PM
Timing Belt Parts Necessary now abeaujuin Honda Prelude 6 07-29-2004 07:47 AM
Tags
2003, 2005, 2005accord, accord, belt, change, cylinder, fan, honda, hybrid, recommended, removal, replace, replacement, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
