what gas should i put in my car? - Honda-Tech
Old 06-14-2008, 07:12 PM   #1
lrcrx90's Avatar
Default what gas should i put in my car?
i just purcahsed a 2004 accord lx and was wondering what was the recomended gas for this car 87 89 or 93. i've gotten a bunch of answers and i need a straight one
lrcrx90 is offline   Reply With Quote
Old 06-14-2008, 07:54 PM   #2
msedacca's Avatar
Default Re: what gas should i put in my car? (lrcrx90)
I'm guessing 4cyl by the LX, so you don't need anything more than 87. Anything more is a waste of money. You can run 93 and you might see a slight hp gain and slight improved MPG, but outside of that, no real perks.
msedacca is offline   Reply With Quote
Old 06-15-2008, 09:40 AM   #3
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Location: Completing my training with my Supreme Leader
Default Re: what gas should i put in my car? (msedacca)
Even the v6 doesn't require anything more than 87. Apparently, if you use premium in the v6, the computer will mess with timing and give an additional 10 hp.
Uncle Ben's is offline   Reply With Quote
Old 06-15-2008, 04:01 PM   #4
bmxrider945's Avatar
87 all the way, its cheaper
bmxrider945 is offline   Reply With Quote
Old 06-16-2008, 02:20 AM   #5
ch0baca's Avatar
Default Re: what gas should i put in my car? (Uncle Ben's)
Quote:
BS! r u kidding me??!
ch0baca is offline   Reply With Quote
Old 06-17-2008, 05:01 PM   #6
msedacca's Avatar
Default Re: what gas should i put in my car? (ch0baca)
Quote:
Nope not at all, that is not the first time I've heard that. I've never seen concrete data to back it up, but apparently thats what Honda says.
Old 06-17-2008, 07:29 PM   #7
JDM_Acccord's Avatar
100 octane race fuel.
JDM_Acccord is offline   Reply With Quote
Old 06-17-2008, 09:06 PM   #8
interstate's Avatar
Honda Accords were made to perform optimally on 87 octane gas.
interstate is offline   Reply With Quote
Old 07-10-2008, 12:46 PM   #9
onlyforLIT's Avatar
Default Re: what gas should i put in my car? (interstate)
I've got an 03 EX V6 6-speed Navi coupe.....and I SWEAR it runs faster/better on 91 oct vs 87.....(in CA there is no 93).......
onlyforLIT is offline   Reply With Quote
Old 07-11-2008, 09:06 AM   #10
vtec_head's Avatar
Default Re: what gas should i put in my car? (onlyforLIT)
Like the others are saying stick with the lower grade 87 you'll be just fine! Even if the myth is correct about a additional 10hp by using Supreme gas you won't really notice it much and it may even lower your MPG. Then you'll be just kicking yourself!
vtec_head is offline   Reply With Quote
Old 07-14-2008, 11:12 AM   #11
Frankv6coupe's Avatar
Well I tried 89 octance last year and the car slowed down. My mph in quarter mile dropped. I went back the week later with regular (87) octane and my mph went back up to normal. By the way I drive 2004 accord ex v6 coupe automatic.
Frankv6coupe is offline   Reply With Quote
Old 07-16-2008, 01:06 PM   #12
vdavenp802's Avatar
Use whatever level your manual suggests, any more and it is a waste. Because, octane is used to control pre-detonation. Knock. That's all. Nothing to do with the amount of horsepower it will generate. Gas is gas at that point. Horsepower is made via compression ratio, which then dictates octane level to contro, pre-detonation.
Any brand will be fine. If you have problems with your gas its the station, not the brand. It all comes out of the same hole it the greound(storage tanks).
All the gains people report are very subjective, since they typically compare two different points in time, when other factors that affect performance are not controlled and not the same. (i.e. ambient temp, tire pressure, barometric pressue, etc., etc.)
Go by the manual, you can't go wrong.
vdavenp802 is offline   Reply With Quote
Smell Gas? bmanuhutu Honda CRX / EF Civic (1988 - 1991) 5 07-27-2010 10:15 PM
my gas light comes on when i start my car but not when my gas is low khronicboy420 Honda Accord (1990 - 2002) 2 12-24-2008 11:18 PM
Better gas mileage Matt53 All Motor / Naturally Aspirated 6 03-05-2007 10:18 AM
car pulls left on the gas, pulls right off the gas. jbell Honda S2000 6 08-29-2006 10:57 AM
wierd thing happening with the gas pedal atm3535 Honda Prelude 12 01-30-2006 02:32 PM
Tags
07, 2004, 2008, 2dr, accord, car, civic, coupe, gas, honda, kind, octane, pressure, put, recomended, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
