Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
V6 accord power steering/idle issue
Old 09-15-2015, 12:09 PM
93egboosted's Avatar
Default V6 accord power steering/idle issue
How's it going? I have a 2003 v6 6speed accord. Issue is at idle the power steering hardly works or at times doesn't work at all, but If you raise the Rpms the slightest bit "100 Rpms" power steering works perfect. Driving the car no issue that I notice.
Changed the pump
Changed the pressure switch
From what I understand is that the car does not have a IACV because it's drive by wire, is there something else that bumps up the idle when the power steering calls for it? Also turning on the ac at idle does not increase the idle rpm
Thanks
John
Old 09-17-2015, 06:16 PM
Default Re: V6 accord power steering/idle issue
TTT any help is appreciated
Old 09-18-2015, 03:34 PM
poorman212's Avatar
Ok, since you asked again.
What is the idle rpm once the car is at normal op temp in park and in drive? In drive with your foot on the brake and you turn on the ac does what does the idle do.
A good cleaning of the TB never hurts - get both sides and the edges of the butterfly.
Old 09-18-2015, 07:33 PM
I realized I posted the first thread in the wrong section.
Idle at normal temp is 750-800, car is manual trans and in neutral if you turn on the ac the idle remains the same unsure if this changes when the car is in gear I will check tomorrow. I will also clean the throttle plate as you suggested maybe some build up on the edges
Thank you for the reply
John
Old 09-19-2015, 03:03 AM
poorman212's Avatar
My bad, assumed it was an auto trans
Being that with the ac on it doesn't go down the PCM is sensing and adjusting for the load.
Is the steering issue something that came about over time or was it something that just started happening one day?
93egboosted
09-14-2015 05:48 PM
Fuzzychaos
Honda Civic (2001 - 2005)
06-21-2015 11:50 AM
kornerk12
02-17-2006 10:58 AM
First Honda 1976
05-01-2004 04:11 PM
Bloodwynch
03-21-2002 06:40 AM
Quick Reply: V6 accord power steering/idle issue
