Transmission Fluid Change
Hello fellow Accord owners I have to change the Trans fluid on my Accord soon its due for one. But my question is it a simple drain and refill like how the service manual says. Or do I have to flush it out like people always tell me. cause I thought that you only have to flush it when it gets rebuild or replaced. And to clean the ATF oil cooler lines. plus I heard there's a filter I can replace or clean is this right or im I forgetting some thing. Any help appreciated.
Re: Transmission Fluid Change
Just drain and fill. No flushing machines. There is a filter you can replace, even though Honda claims it doesn't require changing. Here's a link for How-to.
http://www.brisdance.com/Honda/AutoFilterPage.html
The part number is listed in the link....25450-RAY-003....#7 in the pic
The local dealer should be able to help you out, there are a few online dealerships you can use as well.
Honda dealerships still claim the filter is "lifetime" and doesn't need to be changed. And of course the manual was written way before Honda started recalling the transmissions.
Thank you i can finally change my transmission fluid. when my trans went out about five years ago . the dealership just rebuilt my transmission so i dont have a 2nd oil jet on the silver ATF filler bolt. should i be worried or its all good.
I can only assume they rebuilt the transmission so that it doesn't need the jet kit. If you don't want to assume, you would have to ask them.
I know this thread is old but I replaced my Transmission Fluid with the ATF DW-1 Fluid and its been. Around 3700 miles and have noticed better shifting and it being more smooth. But the performance has been slightly fading and was wondering if changing it again would benefit. since there's still some dirty fluid cycling around in there still.
I change out three quarts as often as it takes to keep the fluid looking clean and red. If the fluid is really dark or brown, you might need to do more than one drain and fill. I never do back-to-back drain and fills, because then I feel like I just poured out the fresh fluid I just put in. So I will wait, usually 10-15k miles between, depends what the fluid looks like each time. I believe HandAaccessories.com has a good deal on a case of DW-1 fluid, which should last a while. I got my last case from them, but that was a few years ago. I changed the filter at 60k, 90k, and will probably change it again at 120k which could be around the end of this year.
My transmission was replaced at 78,000 miles or so and I replaced the ATF fluid at 132k so it was due for a fluid change.
CHANGE THE FILTER. Screw anyone who disagrees, change the damn filter. Wanna see mine after 130k? Trust me, change the filter.
also, I highly recommend removing that dumb hockey puck that I saw a picture of. Use a fluid passage from a Honda odyssey and a fat trans cooler.
dk199160
10-23-2015 11:54 AM
rotorbudd
01-03-2013 01:11 PM
wkdclwnz
09-26-2006 03:56 PM
Overmind22
03-28-2004 09:47 AM
e_r_i_c_
05-02-2003 01:04 PM
