TPMS light on, how to take remove the light - Honda-Tech
Old 09-11-2008, 01:43 PM   #1
hondaracer4vtec's Avatar
Default TPMS light on, how to take remove the light
On the 08's does anyone know how to take the TPMS light out?
hondaracer4vtec is offline   Reply With Quote
Old 09-11-2008, 03:26 PM   #2
kine462's Avatar
Default Re: TPMS light on, how to take remove the light (hondaracer4vtec)
put air in your tires....
there is a tpms module that communicates, with your cluster and ecu so it's alot easier to just put your pressure over 30psi and don't run over any nails!!!
kine462 is offline   Reply With Quote
Old 09-11-2008, 03:32 PM   #3
I swapped my sensors from my stock wheels to aftermarket wheels....Discount Tire did it....I think it is like an air bag(saftey feature) and can not be disabled but not an expert...Some Tech. here should have the answer...Good Luck
gvmotors is offline   Reply With Quote
Old 09-11-2008, 04:08 PM   #4
ekb16's Avatar
if its the actual "TPMS" light then there is something wrong wit the sensors or something else and it has stored a code, bring it to the dealer so they can see wuts wrong wit it and fix/clear the code...if its just the low tire pressure indicator then ur just low on air pressure
ekb16 is offline   Reply With Quote
Old 09-12-2008, 07:49 AM   #5
Default Re: (ekb16)
No there is nothing wrong with the tires just that one rim was off my car for over an hour and the computer needs to re read it.
The air is good all 33psi no leaks. Just needs to re set to reboot the system i guess.
Will removing my battery do anything?
Old 09-12-2008, 09:08 AM   #6
My Name is Nobody
MSchu's Avatar
Default Re: (hondaracer4vtec)
OP... have you read your owners manual as yet by any chance?
MSchu is offline   Reply With Quote
Old 09-12-2008, 09:24 AM   #7
Default Re: (MSchu)
Yeah, is it in there? I might of over read it?
MSchu, did yours come on when you changed the springs or wheels for that matter?
Old 09-12-2008, 10:01 AM   #8
tbone13's Avatar
from my experience, it should reset itself. just drive around and it should go away. if not, maybe the dealer can reset.
tbone13 is offline   Reply With Quote
Old 09-12-2008, 10:57 AM   #9
My Name is Nobody
MSchu's Avatar
yeah.. my tps light is on full time.
I had thought that I read somewhere that a service tech may need to do a re-learn. but then someone else has told me that the system will re-acquire the sensors after a short while. not sure who to believe in this instance, the manual or an online forumite...
Old 09-12-2008, 11:18 AM   #10
Default Re: (MSchu)
Mine is still on for about a month now, guess its not re learning then.
Old 09-13-2008, 01:56 PM   #11
My Name is Nobody
MSchu's Avatar
Then you need to take the car in and have the tech use a sensor initializer tool...
2009 Ridgeline TPMS luciffer Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 10-21-2013 11:01 AM
TPMS on 13 civic taterrill Introduce Yourself 2 06-08-2013 06:10 PM
2007 CRV - TPMS warning light euangincrv Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 15 01-09-2013 01:38 PM
tpms? runhopskipendub Honda Fit 26 05-15-2011 10:11 AM
TPMS Sensors da993 Wheel and Tire 3 05-07-2010 06:31 AM
Tags
06, 2008, accord, accords, civic, grouptpms, honda, light, pressure, remove, reset, sensor, sensors, tire, tpms, user
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
