Tire Pressure/VSA light stays on? - Honda-Tech
Old 05-03-2012, 04:13 PM   #1
Default Tire Pressure/VSA light stays on?
Hey, I've been coming to these forum awhile now looking for answers for problems to my Honda and most of the time I find an answer. Which is a huge help.
I have a 09 Accord EX-L, and 3 days ago I had a flat and had to put on the spare, the car was fine but after a few times driving it, the tire pressure light came on, the VSA light with the '!' beside it, and the brake light, like the emergency brake was on. I checked all the air in the tires, and it was fine, so I figured with the spare, I guess the sensor just thinks its low, and with the spare tire being smaller, making the car a little unbalanced, that's why the VSA and brake light is on.
Well, I put on the new tire, checked all the tires again with the right PSI, and of course shutting the car off to reset the sensors. But, all three lights are still on. Does anyone know why? Is there someway to reset it? Thanks
Murk13 is offline   Reply With Quote
Old 05-03-2012, 05:02 PM   #2
Salami's Avatar
Default Re: Tire Pressure/VSA light stays on?
Have you driven the car yet?
The light should go off after the new tire is installed on the wheel, the pressure is correct on all 4 wheels with the sensor and the car is driven. IIRC the car needs to be driven a speeds above 19 mph to get all of the sensors to transmit.
The TPMS letters are a MIL. It can come on if the spare is installed or if there is a malfunction of the TPMS.
I have no clue as to why the other lights are on.
Salami is offline   Reply With Quote
Old 05-03-2012, 05:54 PM   #3
Yes, I have driven the car around all day with the new tire on, I figured it would go off with the new tire on also.
2009 Honda Pilot VSA ABS error ground? cmb7684 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 01-08-2017 08:56 PM
2008 civic si abs and vsa light don't turn on. Alcatrax30 Honda Civic (2006 - 2015) 4 03-10-2016 03:57 PM
ABS/VSA light on after new abs sensors. B_Swapped93 Acura Integra 5 04-30-2015 06:34 PM
VSA Help: Activation Light stays on, abs/vsa light come on after driving amoebiasis Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 3 02-07-2015 06:16 AM
VSA VSA VSA VSA!!!!!!!!!! Cornering Artist Honda S2000 11 01-23-2007 07:16 AM
Tags
accord, acura, bought, changing, fit, honda, light, s2000, spare, stays, tire, tires, tl, tpms, tsa, vsa, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
