Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Timing Chain - Advice
Old 09-17-2008, 07:17 PM
RichmondLX's Avatar
Default Timing Chain - Advice
Hello, I have a 2005 Honda Accord LX. I have 100K miles on it and I am wandering if I should change the timing chain and water pump. From past experience I had a timing chain break on an older car I had so this is really preventative maintenance to avoid it from happening again. I have called the dealership and they tell me a bunch of stuff about the chain is strong and it won't break, but I continuously tell them that if the chain breaks like it did in my first car that I'm a** out because the engine will be messed up and will cost more. No one will give me a real answer. So does anyone out there have any insight on what I should do? Should I keep searching around to get it changed at a dealership or just trust in there judgement?
Old 09-18-2008, 04:07 AM
My Name is Nobody
MSchu's Avatar
Default Re: Timing Chain - Advice (RichmondLX)
You had a timing chain break before? Under normal circumstances they don't break as usually they are comprised of a dual row of links. I can say you're more than likely okay with your existing chain
Old 09-18-2008, 05:39 PM
SFlCrx's Avatar
i work at honda as a technician. we never changed a timing chain. unless we change the block. at 100k miles water pump would not be a bad idea. also spark plugs and your fluids tranny coolant.
Old 09-19-2008, 04:51 AM
In a Junkyard near you.
Ross 2.0's Avatar
Since the water pump is external I wouldn't even give it a second thought till it starts making noise or leaking. It takes all of 30 minutes to replace it.
Old 09-19-2008, 12:13 PM
Speed_69's Avatar
are you sure the older car that you had the timing 'chain' break didn't have a timing 'belt' instead?
Old 10-01-2008, 07:52 PM
RichmondLX's Avatar
thanks for the help guys.
Old 10-04-2008, 07:41 PM
bracer's Avatar
Default Re: Timing Chain - Advice (MSchu)
I had the 105k service done on my 2003 Accord V6 Navi autoTrans at 104,900. I also had the waterpump replaced and plugs. I had the dealer return the old belt to me. I did a thorough inspection of the belt and my assessment is that it looked nearly new and could have easily 10-15k more....that is of course I personally will drive that much over the next 105k but make your own choice.
The dealer noted that the previous owner had a new transmission installed under an extended warrany at 54,000.
Two400
33
02-10-2017 07:07 AM
brian0918
07-02-2015 10:39 AM
boomersz
03-04-2007 07:55 AM
bart2546
12-31-2006 06:30 AM
bart2546
13
12-30-2006 10:51 AM
Quick Reply: Timing Chain - Advice
