Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Timing Chain 2005 Accord
Old 06-18-2009, 04:51 AM
  #26
In a Junkyard near you.
Ross 2.0's Avatar
Default Re: Timing Chain 2005 Accord
On a pilot I can do it easy. Believe it or not. Having the right tools makes all the difference.
Old 06-18-2009, 06:33 PM
  #27
KWayRacing's Avatar
On a pilot that is believable especially if you do new tensioner with every belt. But that would be jamming and still hard to do. I always get a little bigger smile when I see the job is a pilot. I could not agree with you anymore about the right tools making a hard job easy.
Old 03-07-2014, 02:53 PM
  #28
shophound's Avatar
shophound;I need timing marks for 2005 accord ex cams an crank? also should I change oil pump?
Old 02-01-2017, 06:52 AM
  #29
Hondatex's Avatar
I have a 2005 Honda Accord 2.4L 4 cylinder with 5speed manual transmission still running like a dream at 203K miles. I can't say I've ever had a problem with any of the 4 cylinder v tech engines by Honda. However, I've heard some horror stories about the v6.
Any thoughts?
Old 02-03-2017, 02:55 PM
  #30
DCFIVER's Avatar
Any thoughts?
I think KFC makes the best fried chicken. But I haven't really tried Pioneers. Definitely better than Churches though....
Old 02-04-2017, 05:55 AM
  #31
poorman212's Avatar
Around here you would have to add "bojangles'" to the equation.
Old 02-09-2017, 06:07 AM
  #32
Retired Bill's Avatar
Pretty sure you are talking about the timing belt replacement. It's standard practice to also replace the water pump at that time (easy to get to / when changing cam timing belt and tensioners), and some people also change the oil seals at front of crankshaft and and camshaft ( I might or might not on first 100,000 mile maintenance / yet would change such seals for sure if I saw any sign of a seals leaking oil!) ...
for DIYs, I've notice some well made step by step documentation on internet, including on You Tube. When I do a cam belt, after finding and lining up the marks on camshaft pull and crank pulley (harmonic balancer) to where those marks should be ... I mark the belt and pulleys with a white marker ..a the specific contact next to lining up marks (giving in a service manual for this job) ... and also put arrow on belt twords front of engine. ... then I transfer the marks from old belt to new belt , ... making sure to match teeth counts of both belts exactly. .. this provides a sure way to put your time belt on right the first time. One tooth or rib off on a timing belt is a big headache time suck... that will not let engine run plus require bust down and do it over. ... My two cents.
Retired Bill ...owned a mechanic shop for VWs and the Japanese Auto in the 80s / for preventive maintenance plus engine rebuilds.
Old 02-09-2017, 08:51 AM
  #33
Global Moderator
tech8's Avatar
No, 2003 to current Accord 4 cylinders have a timing chain.
Old 02-10-2017, 07:07 AM
  #34
I stand corrected. Thought I knew but... just looked up parts supply for 2005 Accord and see timing chain or timing chain kits. If I had to or next time I have to do a timing chain: I still think white marking chain and sprockets after getting all in proper position, and transferring marks from old chain to new chain ... keep track of direction chain is moving/ front vs back back of engine position ... is still a great idea to make sure the timing chain job is done right the first time. One tooth off is a time suck.
Cstanis
Honda Accord (2013 - 2015)
03-14-2019 03:32 PM
ziffies
12
02-08-2013 04:50 PM
garagejunkie
10-12-2009 08:20 PM
boomersz
03-04-2007 07:55 AM
Quick Reply: Timing Chain 2005 Accord
