Spark plugs replacement question, Accord 2006 - Honda-Tech
Old 02-10-2010, 11:17 AM   #1
Icon6 Spark plugs replacement question, Accord 2006
Hi there:
A friend of mine went to the auto mechanic and he is been charged $150.00 to replace the spark plugs.
He jumped when he heard the price, but the mechanic states that the 2006 Honda Accord must be connected to the computer or whatever to reset the sensors, such procedure is done everytime the spark plug are changed on that specific model.
Is this true? I ask as many new vehicles come with tons of sensors and chips that older cars do not have, but I am not sure if it applies in this case. Also, just talked to me and the mechanic said the spark plugs must be hooked up to some computer to set them before they go into the engine.
GrizzlyMan is offline   Reply With Quote
Old 02-10-2010, 03:58 PM   #2
BLKFLSH's Avatar
Default Re: Spark plugs replacement question, Accord 2006
If this was a V6 engine, I can understand it costing that much. The spark plugs would be more than half that cost. If it's a 4 cylinder, he got hosed. There is no reason to hook the car, or the plugs up to a computer. All you can do to a spark plug is adjust the gap, but the plugs should be set from the factory, and even if the gap was off, you use a feeler gauge to set the gap, not a computer.
BLKFLSH is offline   Reply With Quote
Old 02-10-2010, 06:00 PM   #3
Aren't Iridium plugs around 7 to 8 dollars a piece, making it 50ish something dollars on a V6 maybe more because of tax?
The mechanic is charging $100.00 per hour then again I do not know if on V6 engines manifolds, plastic covers etc must be removed making it more labor intensive to change them.
Old 02-11-2010, 03:37 PM   #4
BLKFLSH's Avatar
The lowest price I've seen for the iridium plugs is $9.99 at Autozone. They are about $12.00 from a dealership. That's about $70 for the plugs, and $80 for installation. I would never pay someone else to install my plugs, but if you don't want to do it yourself, you have to pay the piper. If it's a 4 cylinder engine, $150 is too much, but it seems reasonable for a V6.
Old 02-12-2010, 06:01 AM   #5
Friend informed me its a 4 cylinder, he is going to take to another mechanic. I would hook him up but he lives 5 hours away in Miami and he is clueless about torque, anti-seize compound.
Thanks for taking the time to reply.
Old 02-14-2010, 12:36 PM   #6
f.e
just do it yourself takes about 20min because of the damn little screw that holds them on and there are six plugs
f.e is offline   Reply With Quote
Old 02-14-2010, 05:23 PM   #7
Your friend is getting raked.
Project Cortez is offline   Reply With Quote
1992 Honda Civic DX wont start. RobTimmerman Honda Civic / Del Sol (1992 - 2000) 13 06-30-2014 09:21 PM
icm or main relay or timing? my1992cb7accord Honda Accord (1990 - 2002) 8 12-17-2011 04:19 AM
Valve Seals Question Sorcereryk Honda Civic / Del Sol (1992 - 2000) 12 05-23-2007 08:10 AM
My engine light keeps turning on!!!WTH? suken19 Acura Integra 23 03-27-2007 11:24 PM
acceleration problem dubfly Honda Accord (1990 - 2002) 5 08-10-2006 11:33 PM
Tags
06, 2006, accord, accord4, change, civic, cost, cylinder, honda, hybrid, location, pilot, plug, plugs, replace, replacement, spark, sprark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
