Parking Brake
Parking Brake
I need to adjust my parking brake. When you pull on the handle it has alot of play and goes up a lilttle before it even clicks and when it clicks it goes all the way back to fully grap. I read in a shop manual that you have to remove the center console and adjust the nut on the handle itself. When I asked a mechanic he told me to adjust it behind the rear wheel and that my car even though it has disc brakes in the rear there is a sepeate set of shoes for the parking brake that could be worn out. What part of this is true and how exactly do I adjust it? Thanks
It Wasn't Me!
1 Post
Re: Parking Brake (Accord1234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord1234 »</TD></TR><TR><TD CLASS="quote">I need to adjust my parking brake. When you pull on the handle it has alot of play and goes up a lilttle before it even clicks and when it clicks it goes all the way back to fully grap. I read in a shop manual that you have to remove the center console and adjust the nut on the handle itself. When I asked a mechanic he told me to adjust it behind the rear wheel and that my car even though it has disc brakes in the rear there is a sepeate set of shoes for the parking brake that could be worn out. What part of this is true and how exactly do I adjust it? Thanks</TD></TR></TABLE>
That mechanic needs to find another line of work. The adjustment is under the console. I can't recall if the Accord does have an adjustment at the wheels or not but it does not have a second set of brakes.
It Wasn't Me!
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord1234 »</TD></TR><TR><TD CLASS="quote">Where is this nut? I took out the shifter trim and even the cup holdlers and still don't know where it is. </TD></TR></TABLE>
It's behind the lever under the storage compartment portion of the console. You actually have to loosen the console enough to lift the back to get to it.
Re: Parking Brake (someone else)
OMG. I'm gunna have to spend my Friday trying to get the rest of the console off. What a pain in the ***! lol
I kinda in the same situation, but I have drums. I was having to click up to 11 to make it fully engage.
I just replaced the shoes and had the drums turned. I put back the drums, press on the brakes a few times to adjust the shoes. But my e-brakes still takes alot of clicks to fully engage.
When I follow the instruction in y Haynes, like you have it here... the shoes eventually starts to rub the drums, but only at one point of the revolution. It seems like only a minor variance, though, but I thought I should check with you guys if this is normal after replacing shoes.
Anyway... if I stop adjusting by then, it would still take a lot of clicks to fully engage the e-brake. But if I continue adjusting until I get a rubbing consistently all the wal around, I'm afraid when the e-brakes are off, there would be more than just a slight rubbing at the one point.
Re: (dbbyleo)
Only lift the rear of the center console to access the adjusting nut. It is not necessary to remove the whole thing.
There is a specification for each vehicle regarding the number of clicks to fully apply the parking brake. Some vehicles are as little as 3 or 4, some are around 10. Just because your shoes rub slightly and you have a certain number of clicks at the handle doesn't mean there is a problem. Check the specification before adjusting the parking brake.
