Need a "No Start" Flowchart For 04 Accord
Can anyone provide me a "no start" flowchart for a 04 Accord 4 cylinder. They can be found in the Helm's manual which I don't have.
Car will crank but not start. Oil pressure light remains ON, and the Check Engine Light does NOT come on at all. The CEL should at least blink for 2-3 seconds during key engagment which it does not.
Pretty sure there may be a problem with the ecu. The AC drain tube clogged soaking the passenger side footwell with water. Water may have came in contact with the ecu circuitry.
Re: Need a "No Start" Flowchart For 04 Accord
Doesn't sound good at all. I diagnosed a similar issue with a 2004 TL and the evap drain tube had clogged and water got into the PCM...fried it. The TL also had blown several fuses, one for the Ignition Coil Packs. Once I put the PCM in the IMMOBI light was out but it still wouldn't crank and that's when I found the blown fuses. Does the IMMOBILIZER light blink with the switch on or while trying to crank? I would open up the ECM and see if there is any water damage.
"Sucks to be You Man" was the only thing I could say.
Now as for the no start on the accord. I would try to swap PGM-FI relays. Or maybe take yours apart and look for a burn mark on the solder joints. One of them may be burnt or broken. Try to solder it back up.
Had this exact thing happen about 3 weeks ago. The customer was so pissed but he bought the computer. Took it back to his house and said he fixed the leak. He came back a week later same issue. The PCM was full of water.
odane403
06-06-2018 08:55 AM
