Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
k20a2 swap into cm5
Old 02-07-2017, 05:13 AM
gonzo5785's Avatar
Default k20a2 swap into cm5
hello im swapping a k20a2 into my boys cm5 and would ike to know if i could use the ecu from the k24 just to get him running i cant find any info on this but i know first hand that some things dont fit without using some common sense. i am swapping over all sensors from the k24 for now just to get him moving and would like to know if i would run into any issues using k24 kstuff on the k20 i already know that the intake manifold fits wierd i believe that the egr? is what hangs of of the side of the head(i am going to block i off) when the intake mani is bolted up i also noticed the sensor from the k20 cam toward the rear of the motor is at a different angle than the k24. i would like to know if there is any other issues that i wil run into at this point including running the k24 ecu any and all help is apreciated and i already have spent the last 5 days researching these issues and all i can find is performance oriented stuff for the swap nothing on just getting it running
Old 02-07-2017, 01:10 PM
gonzo5785's Avatar
Default Re: k20a2 swap into cm5
ok did some more reasearch the intake mani i can cut to fit. i have to also get a water neck for the a2 because the a4 wont fit still up in the air about sensors and ecu but i guess no one has done this and dont blame you theres more options but its not my wallet or build so yea if any one has info please chime in i can and will use all info thanks in advance
wascly
03-17-2007 07:02 PM
Singlecam4dr
04-25-2006 05:10 PM
vtec fan
03-31-2004 10:07 PM
neiche
12-09-2003 10:20 AM
Quick Reply: k20a2 swap into cm5
