Increasing my mpg. Turbo?
#26
Re: Increasing my mpg. Turbo?
thats not how it works. you are still using more fuel because you are forcing air into the cylinders. with a small turbo like you said it will spool much quicker than a large turbo meaning if you were driving 70mph on the highway you would most likely be in boost the entire time...therefore getting worse gas mileage. the motor doesnt have to work any easier to make 150 hp na or 150 hp with a turbo. do some more research on turbos and how they work. go and buy corky bells turbo charging book.
you could potentially get similar gas mileage...possibly even the same....but not more.
even if you could get 5 mpg better the 3k you had to spend to get there wouldnt be worth it. 5mpg x 20 gal tank (thats a big *** tank) = 100 miles per tank or you saved 40 dollars (gas at 2.50/gal)
that is 75 tanks of fuel before you reach the benefits.
the accord is 17.1 gallons so 85.5 miles to the tank or 34 dollars you save over the old mpg. 88 tanks of fuel to get the money back. that is almost 53k miles before you save 3k. but what about the extra cost for oil for the turbo? etc...just not worth it.
My Integra has a 13 gallon tank, and when I fill up it's usually 10 gallons ish just saying.
#27
As long as you're not heavy footed and trying to accelerate faster than you did before, the MPG will increase.
I said a small turbo because it is best in terms of acceleration; i.e. city driving. I had forgot that he had a long commute, so I guess that means highway. But that shouldn't really make much of a difference- maintaining a constant speed requires much less engine power as the engine must only overcome friction, both aerodynamic and kinetic, whereas acceleration also includes inertia as a factor. Less power means less air and fuel needed, so highway mpg should be roughly equal to what it is now. But a larger turbo would be more effective in this situation.
Also, at a constant speed the turbo won't be making hardly any psi.
Cliffs: I know what I'm talking about.
#28
for instance my h22 turns 3.5k at 70 mph. if i were running a small turbo say t25 i would also be boosting at whatever level i had set the wastegate. That turbo will have full boost at 3 k on a larger displacement 4 banger....and even lower the more cylinders you add. even larger turbo's could be trying to run boost at that rpm.
any stock motor running boost at any level will get lower mpgs than the same motor na.
if turbo motors got better gas mileage and made more power than stock dont you think more people would be doing it?
#29
the best way to increase your mileage is to open the motor up a little bit to help it flow better. intake and exhaust should help. my 94 went from 28 to 34 mpg after mods. even with the work in my sig it is getting 25mpg.
#30
How does running no cat give you better fuel economy when the gas has already been burnt prior to passing through the cat? On top of that running without a cat will cause you to run rich. Unburnt gas ftl
#31
Sure that t25 would make full boost around 3500rpms, if there is enough engine load. However just cruising will not produce any boost, even if you are cruising at 8000rpms, the turbo will not make any boost until you produce more load, ie. give it an increased amount of throttle.
You've obviously never owned anything turbo'd because you would know that you aren't in boost 100% of the time.
You can drive around without hitting any boost at all, its really easy, i do it all the time, you simply just don't "smash the gas".
If the car is properly tuned with a turbo set-up and you drive normally, there will be an increase in mpg's.
#32
Road House
1 Post
Its difficult to describe, but basically, the engine needs a higher amount of fuel, to burn all of the gasoline prior to emission, than on a catless vehicle.
#33
A catless vehicle will run rich, resulting in nasty black smoke coming out of your exhaust and high levels of HC - Unburnt fuel. I think I sort of understand what your concept is, but like I said, a catless vehicle will run rich unless tuned.
#34
so why dont turbo cars get better mileage than their na counter parts? ie the early eclipses? gst's got worse mileage.....or the new cobalts? my turbo car never got better gas mileage....no matter how i drove it.
#35
Actually you don't know what you're talking about. For a turbo to make boost there needs to be engine load. Just as you can't rev your engine and make full boost. So your example is incredible wrong.
But it is still all about how one drives. My friend can get ~25 mpg city in his 09 WRX when he shifts early and drives like he's 90 years old. The EPA estimate is 18.
#37
Couldn't have said it better myself.
Most turbocharged production cars (that also have NA engines available) normally have a completely different engine. If it is based off the same engine (which is relatively rare), then it is normally heavily modified so that it will be as reliable as possible- this may lower the mpg.
no matter how you look at it turbocharging a car to get better gas mileage is pointless. simple mods like intake and exhaust will do more than any "gas saving turbo setup". not to mention the cost savings.
any one can drive a car to get better gas mileage...not just on turbo cars. my car is rated at 28 hwy and i got 31 my last trip.
#38
Being in boost is a matter of vacuum/map. As long as he hasn't passed 0in/hg, he won't be in boost. You can be driving any sized turbo at any STEADY rpm and stay out of boost.
#39
neither the gst nor the cobalt have different engines (although they are available). like i said my turbo car never got the mileage it did stock......but guess that doesnt count.
So yes, Mr. OP, it will increase your MPG (as long as you drive economically), however you would be much more well off improving your car's ability to breath and burn fuel more efficiently through NA modifications.
iBrandon
09-02-2004 01:25 AM
