Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord Coolant sensor replacement -- HELP NEEDED
Old 05-08-2010, 05:37 PM
doitmyself2010's Avatar
Icon6 2007 Accord Coolant sensor replacement -- HELP NEEDED
Hi,
I'm planning in replace the engine coolant temperature sensor on my 2007 accord myself, because of error codes of P2158 and P2157 was generated.
Do I need to drain the coolant fluid before I take out the damaged sensor? Considering the sensor hole is pretty small, With the engine cold and the coolant cap closed, I was hoping that the pressure may hold the fluid from spilling all over. Am I way out of the reality?
Does anybody have suggestions?
Do I need to manually clear the error code from the system or it will go away automatically?
Many Thanks.
Old 05-08-2010, 05:54 PM
be professional
Targa250R's Avatar
Default Re: 2007 Accord Coolant sensor replacement -- HELP NEEDED
On an '07 Accord? Are you sure about those?
Old 05-08-2010, 08:09 PM
the codes first appeared during the state inspection, then i went to autozone, they also pull out the same codes. these codes actually refers to the coolant sensor. I bought the sensor from a honda dealership.
Anybody knows if I need to drain the coolant first or it's OK to just replace it sensor with coolant?
Thanks.
Old 05-09-2010, 05:31 AM
diversegsr's Avatar
it wont hurt to drain the coolant....especially with summer right around the corner...replace the sensor...put in new honda coolant...you are good to go
Old 05-21-2010, 06:09 PM
just for whoever has similar situation...
I have replaced the ect sensor without draining the coolant. With the car cold, stopped at garage for over 8 hours, when the old sensor is removed, coolant flowed out slowly, I quickly screwed in the new sensor and the loss of coolant is less than a cup.
one note, you'll need a deep socket to release and tight the sensor.
Old 06-22-2010, 05:35 PM
badboy58's Avatar
Why did you replace your sensor? What was your car doing that you realized it was bad? My cooling fan on my radiator is not starting up, so I am wondering if this is the reason.
Old 06-22-2010, 06:14 PM
Speedx-honda's Avatar
Probably will need replacing as there isn't much you can do to fix if faulty. With the oil in the intake problem check out your pcv valve is clean and working ok
Old 06-25-2010, 06:53 PM
soon2bdropped's Avatar
i had a car overheat with that code. replaced the ect sensor 2 the one in the radio and good to go.. all you need is 17mm deep socket and ratchet. very little coolant comes out. make sure the oring is removed from the sensor.
Old 06-25-2010, 07:32 PM
99blackcivicSi's Avatar
unplug the connector and make sure its not corroded to all hell, if it isn't replace the sensor, if it is replace the sensor and the connector...yes that happens quite frequently
Old 06-12-2011, 01:13 PM
Yazghi's Avatar
Hello,
I have the same issue with ECT sensor/accord 2007 and I want to replace it myself, but I do not know where it is lopcated. would you please help me locate it.
Thanks in advance
Old 06-12-2011, 02:25 PM
drivers side bottom of the radiator
Old 06-26-2011, 12:55 PM
Yazghi's Avatar
Thanks 4 yr help
cruzneel
08-27-2017 12:05 PM
Babong
17
09-20-2011 08:35 AM
joshg3p0
03-31-2011 11:20 AM
robdog09
09-08-2009 09:26 PM
Quick Reply: 2007 Accord Coolant sensor replacement -- HELP NEEDED
