2006 Accord Automatic Transmission Fluid Change
After draining, and I learned there's fill plug I need to take out in the process, can I put the new fluid in through the dip stick, or does it have to be refilled through the fill plug? Thanks, Bill
Re: 2006 Accord Automatic Transmission Fluid Change
You the dipstick tube. It take more time but less work. Less work + more time is always easier and simplier.
If you don't have the time, wait until you do have the time to work on your car. Unlike an oil change, one can do it nicely in 20-30 mins. ATF change takes a long longer in the fill process. Don't rush or you'll spill and waste it.
In any case, make sure you do not rush this drain/refill process and that your levels are ACCURATE. NEVER OVERFILL.
I have a hose and funnel rig for the dipstick tube I use to adjust the level after I've run the engine and transmission. But the 3 quarts go in much quicker through the fill plug. It may be tight that first time you remove the fill plug, but you don't have to install it so tight after that, so it's much easier to remove the second time and every time after that. I've done a drain and fill every 15k miles, and I have 98k miles, so I've done it a few times.
Bad_dude
05-13-2010 04:51 PM
shout2lord
11
12-12-2009 02:19 PM
