Compliance bushing replacement? - Honda-Tech
Old 07-21-2011, 10:41 PM   #1
Default Compliance bushing replacement?
I went to dealer today to do inspection on my 04 accord v6. I just bought it with 120k mile.
After inspection they told me the car is in very good shape but front compliance bushings need to be replaced. I did see the crack in the rubber bushing, the passenger side has 1 inch(?) crack.
I have no idea on this problem, so should I do it immediately or just leave it there?
astr627 is offline   Reply With Quote
Old 07-22-2011, 12:41 AM   #2
Default Re: Compliance bushing replacement?
From what ive heard is the bushings are okay for a little while. (Again just what ive heard) Its there to keep the dirt out. Im gonna try to find a sealant of some sort instead of replacing mine which is the same one and same size crack.
jakefrom is offline   Reply With Quote
Old 07-22-2011, 08:05 AM   #3
Quote:
Dealer told me if bushings are bad, it's likely to damage wheel/tire, causing alignment problem. Also it will damage the lower control arm. The part is cheap, but labor cost almost 400. So that's why I'm not so sure about it. Do you know the normal cost for bushing replacement?
Old 07-22-2011, 07:31 PM   #4
soon2bdropped's Avatar
400.00 seems about right.. to remove the arm and press the old bushing out and press the new one in. vehicle will wander while driving.. meaning it will pull back in forth in either directions. especially over bumps.
soon2bdropped is offline   Reply With Quote
Old 07-22-2011, 11:51 PM   #5
DCFIVER's Avatar
.... Its there to keep the dirt out. Im gonna try to find a sealant of some sort instead of replacing mine which is the same one and same size crack.
Wrong.
DCFIVER is offline   Reply With Quote
Old 07-22-2011, 11:55 PM   #6
DCFIVER's Avatar
Quote:
Try a Honda/Acura indy shop. They may do it cheaper. There is a tool available (I have one) that can be used to R and R the bushings with out removing the entire arm.
Old 07-23-2011, 07:30 PM   #7
Quote:
That's what I'm thinking of. Indy mechanic can do it too. Not a hard job.
Old 07-24-2011, 09:17 AM   #8
Wrong.
My bad i didnt see he meant entire bushing just thought the boot for it
Old 07-29-2011, 06:52 AM   #9
When the bushings break all the way. You will know. The car will handle like sh*t. It may make some noise as well. If you have a good set of hands you can do them yourself. Then when you get them out make sure you mark the slits on the rubber with a paint pen or a sharpie, just draw a line on to the lower control arm. Take it to a machine shop or anyone with a press and pop the old one out and pop the new one in. Just make sure they go in the same way they came out.
DeanHondaPGH is offline   Reply With Quote
Old 07-29-2011, 06:53 AM   #10
*** when you get the arms out mark the direction of the slits in rubber***
Old 12-17-2011, 03:04 PM   #11
Quote:
thank you
Old 12-17-2011, 03:27 PM   #12
redbull-1's Avatar
This is the similar tool DCfiver is referring to. Snap-on and a one or more other companies makes one too.
http://www.sptool.com/index.php?page...mart&Itemid=11
redbull-1 is offline   Reply With Quote
2003 CRV compliance bushing Jimk Honda Element & CR-V 6 06-03-2015 01:38 PM
PCI Bronze Bushing Replacement Parts Phoenix_ITR Road Racing / Autocross & Time Attack 1 12-22-2013 09:47 PM
Compliance Bushing Question OmarR Suspension & Brakes 4 08-25-2013 06:30 PM
Lets discuss "solid" front end bushings ohsnapzafingcu Drag Racing 20 06-13-2013 02:23 PM
LCA compliance bushings removal anyone know? DoubleEx Honda Civic (2001 - 2005) 11 02-21-2010 06:51 PM
Tags
accord, bushing, bushings, compliance, compliant, cost, damage, h22, honda, instructions, pilot, replace, replacement, replacing, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
