Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Check engine problem
Old 06-19-2015, 11:21 AM
hlock's Avatar
Default Check engine problem
So I have a Honda Accord 2003 4 cylinder VTEC and I have the check engine light on. It reads 2 codes the first says rocker arm actuator stuck on bank 1 and the other is a knock sensor malfunction. the problem started in winter when I would drive, anytime I got above 2.5 rpms the engine would get loud and slow way down but not stall out. I talked to someone at autozone and he said it was probably that my timing valve had gone bad and that it would be a costly fix. But when I took it to a shop when they looked it up they suggested an oil change which hasn't really done anything besides the car doesn't slow down anymore when I start driving, but I still notice some hesitation when I go to accelerate. Other post have said to change the oil pressure switch and the knock sensor but I wasn't sure what I should really do because mine seems a little different from others seeing how my car keeps hesitating before accelerating faster.
Old 06-21-2015, 05:04 AM
Lost Again's Avatar
Default Re: Check engine problem
Telling us the "actual" code might help......the vtec code could be tripping the knock sensor.
But again, not a whole lot of information to go on.
Old 06-21-2015, 10:21 AM
hlock's Avatar
Codes were P2647 and P0325
Old 06-23-2015, 03:42 PM
Lost Again's Avatar
Are the codes still there....or since the oil change and re-set they are gone but you just have a "hesitation" issue?
Old 06-23-2015, 10:46 PM
hlock's Avatar
Codes are still there, only went away for a few miles. Also still having the "hesitation" issue
Old 06-25-2015, 03:41 PM
Lost Again's Avatar
Got a volt meter and some time? You need to test the switch and the inputs to it.
JDM SIR-G
01-22-2009 06:06 PM
CrisEK
13
06-12-2005 02:48 AM
CrisEK
06-02-2005 11:46 AM
mprelude
05-17-2005 10:25 AM
StewdaddySiRII
10-17-2004 06:58 AM
Quick Reply: Check engine problem
