Car won't start makes clicking noise - Honda-Tech
Old 09-30-2010, 02:31 PM   #1
Default Car won't start makes clicking noise
Hey H-T i have a 2003 Honda Accord 2.4L the car makes clicking noise when i turn the key on ignition it makes a clicking noise from solenoid, and the car doesn't get cranked at all to start.
List of things i've checked.
1. I checked the battery, i went bought a new a battery to make sure its not that, so it wasn't the battery.
2. Checked all the fuses under the hood and inside of the car no bad fuses at all.
I want to give it a try by checking the "Main Relay" and replacing it, i can't find the location of the relay.
Also, when i turn on the ignition and leave it for twenty seconds the "CEL" flashes five times. I read the code it's the map sensor i unplugged it and tried turning it on didn't work.
Any help & Ideas would be great.
RHD_EK9 is offline   Reply With Quote
Old 10-01-2010, 05:14 AM   #2
Default Re: Car won't start makes clicking noise
It could be several things-starter, ignition switch, transmission switch, etc.
Lets start with the starter:
With car in P or N you can disconnect the positive wire from the starter and use a jumper wire from the positive post on the battery to that terminal on the starter. Be careful as the starter will try to work as soon as you touch that wire to the starter terminal. This can tell you if your starter is bad.
lazlong is offline   Reply With Quote
Old 10-04-2010, 06:05 AM   #3
BuiltforSin's Avatar
If you can't even find the main relay then you should not be trying to work and diagnose the car. Take it to someone who can.
BuiltforSin is offline   Reply With Quote
Old 10-04-2010, 05:10 PM   #4
DELuth's Avatar
wow...you're a big help. I guess you know everything and always have.
The TWO main relays are in the under dash fuse panel. It doesn't matter since that isn't the problem.
Your problem is most likely a bad starter IF the clicking is coming from the engine area. The starters on those engines are crap. Use a pipe or breakover bar or anything long and heavy to tap on the starter while someone is trying to start it. You may get it to start again that way so it can be driven to where it will be fixed. The starter is hiding underneath the intake manifold.
DELuth is offline   Reply With Quote
Old 10-07-2010, 11:57 AM   #5
^^agreed, it's probably the starter. The solenoid is throwing the starter gear out ("click") but the starter doesn't have the ***** to turn the engine over. Replace the starter and you're good to go. Depends on transmission, you can get a reman from Honda (m/t only) for $309.03 exchanged or a new unit (a/t) for $379.88. HTH
Steve@Spreen is offline   Reply With Quote
Old 10-07-2010, 01:17 PM   #6
skracer13's Avatar
Test your to see if it is indeed your starter, have someone try to start the vehicle and you tap on the starter. If it starts right up then it's definately the starter. It won't always work but its free to try.
skracer13 is offline   Reply With Quote
Old 10-09-2010, 10:11 AM   #7
Starter, common problem on that car
chiautorepair is offline   Reply With Quote
Old 12-11-2010, 03:22 PM   #8
was it the starter? im having the exact same problem, checked and tried to jump battery and checked the fuses
jz1122 is offline   Reply With Quote
Old 12-20-2010, 07:16 PM   #9
Kev2010's Avatar
Check the starter, sounds as if your fuel pump is working.
Kev2010 is offline   Reply With Quote
Old 12-25-2010, 07:30 PM   #10
Chiovnidca's Avatar
Does it make 1 click or a series of clicks?
Chiovnidca is offline   Reply With Quote
Old 12-27-2010, 11:23 PM   #11
hatchet_honda's Avatar
sounds as if tho the OP isnt really familar with engine work. but def check your starter . its getting power if its clicking, main relay is ruled out. man 300 bucks for a starter? eff that
hatchet_honda is offline   Reply With Quote
Old 12-28-2010, 03:59 AM   #12
Quote:
Originally Posted by hatchet_honda View Post
...man 300 bucks for a starter? eff that
Man, I'm so tired of saying this. lol. Every town has an alternator re-builder. They can usually do it for less than $100 and a lot of times you can have it back the same or next day.
Old 12-28-2010, 10:30 AM   #13
Quote:
never ever seen a place around me that rebuilds alternators/starters. ill have to search for a shop that does that and see what i find. im curious now
Old 12-28-2010, 11:42 AM   #14
bump...sorry, wrong page
Old 01-07-2011, 12:16 AM   #15
Quote:
ya i got the same problem wat was it...cause i dont think its the stater
xGBLOCKx13x is offline   Reply With Quote
Old 01-07-2011, 05:19 AM   #16
be professional
Targa250R's Avatar
Quote:
Why not?
Targa250R is offline   Reply With Quote
Old 12-26-2011, 08:10 AM   #17
So what was the problem? and how did you guys fix this? I am having the same problem.
Gary W is offline   Reply With Quote
94 EX wont turn over, good battery, no solenoid click and weird humming, etc...help! Popsgarage Honda Accord (1990 - 2002) 0 10-10-2015 08:36 PM
1992 LS start electrical problem drno Acura Integra 3 06-06-2010 12:28 PM
Car wont start: relay clicking, headlights turn off electronics help! HELP! turbotime Honda Civic / Del Sol (1992 - 2000) 6 11-30-2007 01:09 PM
00 civic wont start (stumped) torr Tech / Misc 2 04-11-2005 04:58 AM
Ignition on relay just clicks, no start? Ski11z Honda Civic / Del Sol (1992 - 2000) 6 04-29-2004 07:17 AM
Tags
2006, accord, buzzing, civic, clicking, fit, honda, ignition, makes, noise, prelude, soun, sound, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
