Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Can you turn off seatbelt chime?
Old 05-13-2008, 07:46 PM
  #26
Splaturn's Avatar
Default Re: Can you turn off seatbelt chime? (someone else)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone else &raquo;</TD></TR><TR><TD CLASS="quote">
Awesome. You know what else those 2 little wires do? Tell the SRS control unit your seatbelt is buckled which affects airbag deployment. So now you have the potential for airbag deployment in a situation where if you had not tampered with the system it normally may not have. Or it won't deploy when it should.
He was just asking how to get it to stop beeping...he obviously doesn't care about wearing a seat belt, honestly, i'm not a cop, there's no reason for me to try to get him to do so. What he was interested in was how to stop the beep, and I told him. Simple enough. If you don't like it, don't do it.
Splaturn is offline
Old 06-09-2008, 07:26 AM
  #27
bic032's Avatar
Default Re: Can you turn off seatbelt chime? (Splaturn)
theres wires in the buckel (the part where you put the metal peace into) put those together and that will stop the beeping and the button that is in you door jam un skrew it off your door jam and put those together to adn if you want to know to start your car with out pushing the cluch there are two sensor cout the wires and put them together (one sensor has two wires put those together and the other sensor put those together...
bic032 is offline
Old 06-09-2008, 08:31 PM
  #28
ch0baca's Avatar
Default Re: Can you turn off seatbelt chime? (bic032)
i drove one time without the seat belt on for about 5-10 mins, and it just stops beeping after that time, weird
ch0baca is offline
Old 06-09-2008, 10:37 PM
  #29
jdmitr's Avatar
Default Re: Can you turn off seatbelt chime? (ch0baca)
I am pretty sure it comes from inside the integrated control unit.
jdmitr is offline
Old 06-13-2008, 01:39 AM
  #30
bic032's Avatar
Default Re: Can you turn off seatbelt chime? (jdmitr)
if you just do what i said you wont have to through the dash and find the chimmer
bic032 is offline
Old 08-15-2008, 02:03 PM
  #31
soshorses's Avatar
I so totally figured it out for the 05 Civic LX.
1. unplug the black plug under the seat.
2. place a paperclip jumping the green wire and the blue with red strip wire in the loose in of the plug coming from the floor.
3. Reset srs light on dash using the paperclip method.
NO MORE BEEP BEEP!
soshorses is offline
Old 08-15-2008, 07:24 PM
  #32
Accord1234's Avatar
Default Re: Can you turn off seatbelt chime? (soshorses)
o Yea, lets disable the airbag for a seatbelt. real smart
Accord1234 is offline
Old 08-15-2008, 07:50 PM
  #33
In a Junkyard near you.
Ross 2.0's Avatar
Putting non API 0W-20 in a car that is designed for 5W-20 isn't too smart either...
Ross 2.0 is offline
Old 08-16-2008, 11:09 AM
  #34
cashdealer07's Avatar
Default Re: (Ross 2.0)
the whole fact of trying to disable the beep cuz ur not responsible enough to wear your seatbelt isn't smart at all. If ur just going down the road and u don't wanna hear it then just blast ur stereo.. and if you don't like that idea then get u a pair of these..
And if you don't like that idea do w/e the hell u want. I just hope you will realize how much of a dumbass you are when u do have a wreck. None of this makes sense!!
You're trying to remove the annoying beep to make it your ride a more luxurious cruise of death? I don't get it..
About a month ago I had a wreck in my 06civic ex going 36mph when I hydroplaned & took a 20ft roll into a ravine. Coming to a stop upside down in a creek only a foot deep. Why am I still here? My F**KING SEATBELT.. WEAR IT!
pix of my car being pulled out of the ravine
cashdealer07 is offline
Old 08-18-2008, 07:20 PM
  #35
Splaturn's Avatar
^^Get off your high horse
OP said it's not often that he doesn't wear his seat belt, and its usually for going up and down the driveway for mail.
If you drive like a dumbass, you'll realize that you probably are one. Don't get on his case for driving up and down the driveway (my friend's driveway was 3/4 of a mile long, fyi, so I understand the reasoning for doing so to get mail)
Stop driving like a douchebag in the rain, and odds of you hydroplaning is pretty low.
Who said the OP is going to drive 64MPH down his driveway in blizzard condition to get mail?
Again, get off your high horse. It's private property, if he wanted to let his 12 year old son drive, he has the right to.
Thank you.
Splaturn is offline
Old 08-20-2008, 07:05 PM
  #36
cjo_28's Avatar
Default Re: (Splaturn)
It can't be done. Even if you short the seat belt switch, it will eventually set an SRS code because the system will think the switch is shorted.
The same thing happens if you leave the seat belt constantly buckled (You're not behind it, but it's buckled. You get out of the car, it's buckled. Get it?).
cjo_28 is offline
Old 08-20-2008, 08:51 PM
  #37
soshorses's Avatar
Default Re: (cjo_28)
ok, I will bite. How long is it supposed to take to send the SRS code? I haven't had any problems with it since I did it.
Also, I didn't disable the air bag. It is still plugged in. I fooled the system into thinking the seat belt was plugged in so that I could freely use my seat belt when I am driving down the road, but I don't have to listen to that high pitch beeping when I am going from the house to the barn down a private gravel road.
Old 08-21-2008, 07:51 AM
  #38
JBuckland's Avatar
Default Re: (soshorses)
Well I wear my seatbelt because of the beep. So I don't mind that but someone brought up cleaning there car and leaving the doors open and playing music. Is there a way to stop the door chimes? There shouldn't be a safety issue with that should there?
JBuckland is offline
Old 08-21-2008, 06:55 PM
  #39
MustangLX6.0's Avatar
Default Re: (JBuckland)
This is the stupidest thing ive ever heard, You go ahead and "fool" your car into thinking your buckled up and when your dumbass gets in a wreck and the airbag deploys and possibly kills you. Your SRS system is designed to save your life when you get in an accident grow a brain and wear your seatbelt until you turn your car off.
MustangLX6.0 is offline
Old 09-20-2008, 06:15 AM
  #40
jdmland's Avatar
Default Re: (MustangLX6.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MustangLX6.0 &raquo;</TD></TR><TR><TD CLASS="quote">This is the stupidest thing ive ever heard, You go ahead and "fool" your car into thinking your buckled up and when your dumbass gets in a wreck and the airbag deploys and possibly kills you. Your SRS system is designed to save your life when you get in an accident grow a brain and wear your seatbelt until you turn your car off.</TD></TR></TABLE>
Wow nobody can read, I've said it how many times in this tread???? WE ARE NOT HERE FOR SAFETY, WE ARE HEAR TO FIND OUT HOW TO GET RID OF THE BEEPING.
jdmland is offline
Old 09-29-2008, 02:42 PM
  #41
vapor40's Avatar
Default Re: (jdmland)
Im not sure how you could turn off the beeping. The extenders seem like the best idea here so far. As far as safety goes I would like to be able to choose to buy a car without airbags, abs and vsa. My old MR-2 has none of them :-) wow i am still alive !! how does that happen? I wonder how much money we could save without paying for all of that crap.
vapor40 is offline
Old 09-29-2008, 04:36 PM
  #42
Power of Dreams's Avatar
Default Re: (vapor40)
Guys, the beep is emitted from the beeper which is integrated in the gauge control module assembly. Power and ground flow through two transistors.
So, unless you're brave enough to micro-solder on a circuit board and potentially damage your gauge control module, it's not possible.
Power of Dreams is offline
Old 09-29-2008, 09:33 PM
  #43
soshorses's Avatar
Under the drivers seat, with the car turned off. Unplug the black plug, use a paperclip to jump the green and the black wires, and leave it there. If the air bag light does come on look up the paper clip method to reset the light. It does work.
I would advise that you still wear your seat belt! If you have an accident the air bag will deploy as if you did have your belt fastened, instead of at the 2nd stage for when you don't have it fastened.
What this does is trick the system into thinking your have fastened the seat belt. I still wear my seat belt when I am on the road but I can now drive around the job site a 3 mph without hearing that stupid bell.
I did this about a month ago, and the air bag light has not come on, and I have not had any problems with my guages.
Old 05-19-2009, 01:33 PM
  #44
New User
hikerman's Avatar
Icon6 Re: Can you turn off seatbelt chime?
i have an '05 cr-v and i have been bothered by the chime that everyone is talking about. this beeping is obscenely loud and drove me insane. THERE IS A WAY TO FIX IT. i would not recommend this to anyone who isn't mechanically inclined. i am a 19 year old college student and i fixed it in an afternoon. the beep comes from a small speaker located behind the speedometer and in the "gauge unit". basically i took my dashboard apart, then took what im calling the gauge unit apart, and found the circuit board that controls the speed gauge, the tachometer, the temp, and the fuel gauge. there is a small blue speaker on this board that you can remove. i tried to cover it w glue at first, then just removed the whole thing. i have installed everything back in the car and seems to be working ok. only prob is the gauges are a little off.... so mark them before you remove the needles... good luck. you will need it.
'05 cr-v LX
-component speakers
-more to come
hikerman is offline
Old 05-20-2009, 06:12 AM
  #45
Oracle of GDD
Ross's Avatar
My girlfriend traded in her Prius for our Accord...and if you guys think the Accord's beeping is annoying, you haven't seen anything until you've driven the Prius.
It beeps about 5 times when you start it...beeps continuously in reverse...and if there's one seatbelt off, it will beep with increasing fury and frequency until you buckle it. The Accord seems non-intrusive by comparison.
Ross is offline
Old 07-07-2009, 09:24 AM
  #46
Stew Pidasso's Avatar
I know what the op is saying. I have an 09 Accord EXL-V6. I always wear my seatbelt. My dad died because he wasn't wearing his. I don't always buckle mine right away and I find it annoying when the car beeps at me for it. Not only is the beeping annoying but now my girlfriend is always telling me to buckle my seatbelt before we pull out of the driveway so I don't set the annoying chime off.
Stew Pidasso is offline
Old 07-07-2009, 11:38 AM
  #47
acura_el2000's Avatar
WOW the amount of **** smoking ********* preaching safety in this thread is astounding! Go do some community service or something if your that concerned with the well being of others.
Also READ, the OP wants to drive on his DRIVEWAY without a seatbelt..some people actually have long driveways.
-OP I know that in my fathers Corolla there was a trick to disable it... you had to turn the keys to accessory (II) and clip the belt in and out about 7 or 8 times, the chime would sound off twice to let you know it was disabled. Try this method out on your accord it could work.
oh and just for the ********, the reason I disabled it was because on Thanksgiving I had gotten a bunch of groceries and a turkey and set them on the passenger seat.. The car thought it was an unbuckled passenger and beeped for nearly my whole trip home.
stupid electronic nannies like these are ridiculous and should never be considered safety measures, because if you are too stupid to buckle your seatbelt without an annoying chime then you are the lowest denominator, as in DUMB AS ROCKS. Whats next? A chime to let you know that you are driving with only one hand? or a chime to let you know that you haven't looked into your rear view mirror in the last 2 mins?
acura_el2000 is offline
Old 07-08-2009, 08:35 AM
  #48
checkZvtec's Avatar
just cut a rear buckle & stick it in the slot.
checkZvtec is offline
Old 07-08-2009, 09:58 AM
  #49
striker81's Avatar
There for safety, leave it alone lol.
striker81 is offline
Old 07-08-2009, 10:02 AM
  #50
spags930's Avatar
my friend and i went to a junkyard and found a totaled accord and we went ahead and cut the buckle ends off and plugged them into his and no more beeping. total cost 6 bucks
spags930 is offline
Quick Reply: Can you turn off seatbelt chime?
