Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
bad barometric pressure sensor
Old 02-17-2012, 08:12 AM
wutangwisdom's Avatar
Default bad barometric pressure sensor
my g/f 04 hond accord is getting a bad barometric pressure sensor is faulty, as i am aware the barometric pressure sensor is welded to the cars ecu? so I am guessing i need to replace the cars ecu. If that is correct that leads me to my main concern. Can i have a mechanic install a ecu for it or does a honda dealership need to install this.
Old 02-17-2012, 08:45 AM
redbull-1's Avatar
Default Re: bad barometric pressure sensor
The code is usually due to blockage in your air intake. Check and replace the air filter if necessary and check for blockage in the air intake tube, all the way to the throttle body.
Old 02-17-2012, 08:59 AM
ive done all that cleaned all the way from air filter to throttle body
Old 02-18-2012, 08:23 AM
justinsbg's Avatar
What code is your PCM storing?
Old 02-19-2012, 04:50 AM
im not exactly sure what the code number is but when i had it checked months ago it was a bad baro sensor reading
Old 02-19-2012, 06:41 PM
D-JET's Avatar
The PCM uses the MAP sensor as a BARO, MAP and BARO are integrated to each other.
Old 02-20-2012, 06:29 AM
they are integrated to eachother? i had the map replaced and then the baro sensor failure code appeared
supercoy101
16
02-10-2010 09:09 AM
Fairburn
16
09-16-2009 04:36 PM
WhippinTheLude
10-23-2004 02:56 PM
SilverIntegra
04-16-2002 11:32 AM
austrian type-R
09-17-2001 12:41 PM
Quick Reply: bad barometric pressure sensor
