B12 Code Honda accord - Honda-Tech
Old 04-29-2009, 04:13 PM   #1
gettin it's Avatar
Default B12 Code Honda accord
Ok, while driving the car the engine code pop on and it says B12 and the little wrench light is on, my engine oil % is at 15 right now, could that be the problem? When i change the oil do i need to take it to a dealer to have the codes taken away? Or can i reset it by moving the battery terminals and leaving them off for a min. Any help will well appreciated.
gettin it is offline   Reply With Quote
Old 04-29-2009, 04:19 PM   #2
ITLNstallion818's Avatar
Default Re: B12 Code Honda accord
b12 i think is oil change, tire rotation
ITLNstallion818 is offline   Reply With Quote
Old 04-30-2009, 06:50 AM   #3
draken187's Avatar
if u hold down the odometer button while its on the oil life screen it resets it... as far is a the wrench and then codes thats just ur maintenance minder... anything being wrong would pop the check engine light.. so ur good.. just get ur normal maintenance done and reset it...
draken187 is offline   Reply With Quote
Old 04-30-2009, 10:06 AM   #4
gettin it's Avatar
Quote:
Ok so how would i go about removing the the wrench light after i have done the oil change and tire rotation?
Old 04-30-2009, 12:53 PM   #5
gettin it's Avatar
Got it reseted by pushing and turning the od switch. Thanks guys.
OBD1 Trouble Codes jdmd15crx Honda CRX / EF Civic (1988 - 1991) 7 08-18-2016 07:45 PM
code 22, vtec solenoid pressure switch on JDM B18C, code wont go away n1_egsex Honda Civic / Del Sol (1992 - 2000) 0 09-01-2007 04:00 PM
OBD1 Codes j_bizach Acura Integra 0 02-17-2007 03:31 PM
Code 21 and 22 on a P75 ecu, wtf? -KangaRod- Honda Civic / Del Sol (1992 - 2000) 6 06-22-2005 06:45 AM
Code 22? endlesswinterco Honda Civic / Del Sol (1992 - 2000) 3 01-10-2004 02:26 PM
Tags
06, 12, 2006, 2008, accord, b12, check, civic, code, codes, engine, honda, maintenance, minder, odyssey, service
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
