2008 Accord engine wont turn over, wont crank up - Honda-Tech
Old 03-08-2017, 01:29 AM   #1
Icon5 2008 Accord engine wont turn over, wont crank up
hello im new on here and i need help. I have a 08 Accord 2.4L Automatic trans. I stopped for gas yesterday and it would not crank up. When i turn the key the green key light blinks once and i can here the starter click but the engine will not turn over. And also when I lock the doors with the key the horn does not beep when pressing the button twice. If anybody has any input I would greatly appreciate it. Thank you
steven253 is offline   Reply With Quote
Old 03-08-2017, 08:44 PM   #2
Default Re: 2008 Accord engine wont turn over, wont crank up
Have someone give you a jump. If it works, probably a bad battery.
prodjay10 is online now   Reply With Quote
Old 03-09-2017, 01:23 PM   #3
Quote:
the starter was bad. I replaced it and it fired right up. Sucks you have to take the exhaust manifold off to get to the starter though. Thanks for your input
Wont start with key, only by jumping starter bigboi407 Honda Civic / Del Sol (1992 - 2000) 9 04-09-2016 04:27 PM
89 honda accord lthsmokey Classic Hondas 3 10-05-2015 02:05 PM
Need help ASAP fuel pump relay single v 95 dx coupe 91siRjdmMob Honda Civic / Del Sol (1992 - 2000) 6 09-04-2011 09:12 PM
check engine light Oregonized Honda Accord (1990 - 2002) 1 09-20-2007 06:24 PM
86 honda accord start problem need a little help Mx3Kfze Honda Accord (1990 - 2002) 2 12-31-2004 04:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
