2007 honda accord wont start - Honda-Tech
Old 01-25-2013, 07:35 PM   #1
Default 2007 honda accord wont start
does anyone know what the voltage at the coil from the ecm/pcm is supposed to be when cranking the motor over. i have zero from ecm/pcm. or why i have zero is this from bad crank position sensor or other
wades2001 is offline   Reply With Quote
Old 01-25-2013, 10:04 PM   #2
Default Re: 2007 honda accord wont start
So your saying that the engine turns over but you aren't getting spark? You've already tested the ignition coil? If you're tps was bad you would be getting a cel, are you? Sounds like the igniter to me, hopefully this helps.
EternalHour is offline   Reply With Quote
Old 01-26-2013, 11:35 AM   #3
Quote:
i have spark, the car is not starting tho/ i tried starting fluid to see if it would run on it and it wont so i dont think spark is enough plugs are getting wet so must have gas however car has been sitting awhile. seems like i read somewhere car will not start with bad cps.
need some ideas on how and what to troubleshoot. i have 12 volts at coil with key on from blk and white wire and when cranking i have zero volts from ecm/Pcm really dont know if this means a damn thing oops .... car just wont start.
Old 01-26-2013, 11:36 AM   #4
oh and thanks for any and all help
Old 01-26-2013, 09:10 PM   #5
PowerUser's Avatar
Do you have a OBD2 scanner? if not borrow one from a friend or a local parts store and see if there are any more detailed codes.
PowerUser is offline   Reply With Quote
Old 01-27-2013, 05:36 PM   #6
Oh, I thought you said you had no voltage to the coil? If you do then you can use an HEI or similar spark tester to see the intensity of the spark at each plug.
*EDIT*
Just realized in my original reply I said tps, I meant cps.
Old 01-28-2013, 10:31 AM   #7
i took fuel pump out and drained gas put in 110 octane and no luck i have fuel and spark and it still wont run.
Old 01-29-2013, 02:09 AM   #8
No cel at all? When you turn the key does the engine crank? Does the engine chug like it's not getting enough fuel or maybe flooding because of too much fuel? Or does it just click? Please provide more details and a list of things that you've tried already.
Old 01-29-2013, 04:04 PM   #9
can any one tell me if there check engine lights goes off after a couple seconds with the key in the 2nd position before starting it? mine stays on does this mean anything
Old 01-29-2013, 04:08 PM   #10
somethings i have tried it compression around 110 for all little low but been sitting for awhile. sprark got 12 volts from bat and got trigger signal from ecm. fuel injectors is a hard one i checked one today and 12 volts going to in and pulse from ecm. oh and took fuel pump out and drained tank and put racing fuel in. and i listen for pump to run and it comes on. and i mean you could eat off this motor. only 20 k on it
Old 01-30-2013, 10:55 AM   #11
you now need to do a scan. especially since the engine check light stays on when the ignition is switched on. it usually stays on for 2sec
geoandy99 is offline   Reply With Quote
MCU problems aporter91 Honda Civic (2001 - 2005) 1 08-26-2015 09:41 PM
Help with VSA Light! outlier25 Honda Civic (2006 - 2015) 6 02-25-2013 12:35 AM
ecm/pcm relay fuse eddygp Honda Element & CR-V 0 10-02-2010 08:57 PM
ECM/PCM on 02 honda civic tipper Honda Civic (2001 - 2005) 6 07-26-2009 09:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
