2007 EX: SRS light flashes when car is locked?
Hello looking for opinions,
2007 EX V6, noticed tonight when I locked car, a red lightstarted flashing in cluster. It's the SRS light. If I unlock the car, it stops. If I pull hood release it stops. This is all with ignition off, key out of steering lock.
Battery has been drained a few times this week, I am sure this is the reason why now. Car has 106K on it.
Thanks for any comments or suggestions.
Re: 2007 EX: SRS light flashes when car is locked?
A bad battery will do crazy things on this car So first get a new/good battery clear all codes and do a cable reset how? with the battery out of car short together the 2 main cables for 10 min This sort of reboots the comp.
Sorry, this all happened in the dark last night. I also installed a brand new battery this week, prior to this post. The red light isn't the SRS light, it's the security red light just below it. I don't remember this light flashing repeatedly, after locking the vehicle. Here's more.... it will only blink if I use key fob (button) to remotely lock the car. If I use the power door lock button prior to exiting the car, it doesn't flash. If I sit in the car and lock it with key fob, it flashes, but if I pull hood release, it stops.
Thanks and sorry for the initial wrong description of the issue.
AznJohn33
02-11-2004 03:04 PM
