2007 Accord v6 key won't turn in ignition
When the key is put in the ignition and attempted to be turn it will not turn similar to when the steering wheel needs to be turned for the lock cylinder to function. Is this a anti theft issue or is it a ignition lock cylinder problem? Car is in park, and the steering wheel is locked, but turning steering wheel does nothing. Key can only be stuck in, will not go to accessory or crank position.
Re: 2007 Accord v6 key won't turn in ignition
I thinks there is an issue in its battery so it had not ignite properly.If there is any other issue so there is need of proper checkup of this car.So then we sort out it.Simply you can take it to mechanic he will know better about it.
CNCProgrammer
Honda Civic (2006 - 2015)
12-15-2017 03:22 PM
maryk2121
06-25-2013 11:35 AM
