Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord - Multiple fuses for accessory outlet?
Old 07-13-2009, 11:07 AM
loki2323's Avatar
Default 2007 Accord - Multiple fuses for accessory outlet?
Two questions:
1. Does anyone know if the accessory outlet (cigarette outlet) has more than one fuse? I was messing around with my sirius unit and blew a fuse for my radio (my sirius unit is mounted in the storage compartment and the power line is spliced in with the accessory outlet).
I replaced the fuse and the accessory outlet isn't giving me any power still.
2. Are both accessory outlets running off the same line? The one by the dash doesn't work but the one in the glove box does. If they are both on the same line then I would assume that I killed the one near the dash.
Old 07-13-2009, 12:22 PM
ekb16's Avatar
Default Re: 2007 Accord - Multiple fuses for accessory outlet?
u could have blown more than 1 fuse..i would just check them all
Old 07-14-2009, 07:19 AM
loki2323's Avatar
I replaced two blown fuses and the manual doesn't show anything else that ties into the radio or accessory outlets.
I can't find anything that shows if the two outlets are wired to the same fuse. If they are then that means that I killed the one and will need to replace it.
Old 07-14-2009, 09:57 AM
New User
CARCOOL's Avatar
Hey
i had the same problem couple of months ago and I was left with no choice rather than to replace the fuses.They were costing me out of budget.My friend told me about www.autopartsway.com .Y dont u check it out.Hope ur problem is solved too.
loki2323
Audio / Security / Video
07-22-2015 05:48 AM
Punkfarter
10-26-2012 04:23 PM
Rik Emmett
02-14-2010 10:50 PM
IP RACING
11
05-06-2008 08:31 PM
netanderthal
01-20-2006 03:12 PM
Quick Reply: 2007 Accord - Multiple fuses for accessory outlet?
