2007 Accord Main relay 2
Instructions on my fuel injection cleaning system (OTC) says to "Remove PGM-FI Relay 2 at LH side of dash" to disable fuel pump during cleaning process. I've searched relentlessly and so far can't locate it. I've found what I believe is the Main Relay, but no go on "#2". I did find a Fuel Pump fuse (15amp) but removing it also disables the ignition.
Any thoughts much appreciated
Larry
Larry
Re: 2007 Accord Main relay 2
Found it. Thanks Tech8 it was right where you said. There was no access panel for the relays. Caught a glimpse of them up above the fuse panel and had to remove the kick panel to access it. Mission accomplished - injectors cleaned.
Thanks again
Thanks again
deadhead23
01-15-2021 10:43 AM
Jcgbeasttube
Honda Civic (2006 - 2015)
03-19-2018 10:07 PM
uneekcrx
04-11-2002 06:59 PM
