2005 /Honda/Accord/ 4CYL
Hello there,,
I am not sure that is why i am trying to get some advice from you.
I would like to find out what cause my battery drain??? .
I am thinking it might be the Stereo makes battery drain.
Problem:1) Stereo Led Blinks and when it blinks the station come up.
( I can hear the radio station when it blinks)
2) Led (Back light) goes off while driving and come back on it self
3) Above #1 - that issue occurred when ignition was off.
I already replaced battery couple month ago // not even 1 year.
I have replaced starter and other small accessory.
and today i had to jump start it.
Re: 2005 /Honda/Accord/ 4CYL
Try and get your hands on a amp probe and watch the draw on the battery, if it seems to high, like over .05 milli amps after 5 minutes (unless you have blue tooth) then try and pull the radio fuse and see if the draw drops
Do your dash lights dim too? I had a problem in my 05 accord EX a year ago. All the lights would "pulse". I replaced the fuel filter, fuel pump, battery, then decided to replace the alternator (which I didn't think it was because I JUST replaced it a month prior). Turns out it was the Alternator. I got a bad one. idk if that helps but there ya go
ssmdhondadriver
08-16-2010 09:44 PM
GTIDamien_407
06-07-2010 05:18 PM
JayhawkMom
11
03-27-2009 09:16 PM
