2004 Honda Accord 4 cyl Low beam
Hello Everyone,
My honda accord's passenger side low beam has gone faulty, here is what i have checked so far:
Bulb is fine
Fuse for low beam under the hood is fine
DRL fuse in the driver side kick panel is fine
What I have tested so far:
I checked the plug of low beam and found that both the pins have continuity in them. Now i am really confused. If this is a short then why isn't any of the fuses blown?
Also, what do i do now?
Please help
Thanks
Re: 2004 Honda Accord 4 cyl Low beam
I have the same issue and can't find a solution for it, can someone help, I have a 2005 Honda accord lx
Last edited by Ramon De Silva; 01-27-2017 at 11:56 PM. Reason: needed to add vechile
For the right/pass side the RED/GRN wire should have battery voltage when the lights are on.....test for it, is it there? If so then verify that the BLK wire has continuity to ground, does it?
Tahir Karamat
11-06-2016 03:53 PM
