2004 Accord V6 problem with sensors
I have a 2004 accord v6. My traction control lights comes on randomly and doesn't allow the car go above 3 rpms. I been doing research and some say the throttle positioning sensor needs to be replace or the acceleration pedal sensor needs to replace. Does anyone know which one is it?
Re: 2004 Accord V6 problem with sensors
For the TCS indicator issue, if it is ABS/TCS component related, you may need a scanner/reader that can also read Honda ABS trouble codes.
Sorry if this is too old to bring back up again, but I hate unresolved threads.
I suspect the OP suffered from dyslexia and/or mushy fingers and meant to type P2138 as the code (not P2318).
P2138 is the accelerator pedal position sensor code. My '04 went through this a few months ago. It would go into limp mode, the accelerator pedal was just a little off in its response, the CEL/ABS/TCS lights would come on. I drove it like that for a few months randomly and got by with just restarting the car whenever limp mode would hit. A quick restart would usually fix things for at least a few miles. Eventually, I got sick of it and replaced the sensor. I went OEM through majestic Honda, bought the entire assembly together (part 37971-RCA-A01). It's a simple bolt on.
privateeye
04-30-2020 04:15 PM
rmiv1985
06-27-2019 04:10 AM
jeffmath
08-06-2018 05:34 AM
