2004 Accord EX Shudder on Acceleration - Honda-Tech
Old 08-17-2009, 08:39 PM   #1
New User
Default 2004 Accord EX Shudder on Acceleration
I have a 2004 Honda EX with auto transmission. My issue is a shudder that occurs when accelerating (even gently) between 50-60 miles an hour (roughly 2k – 3K RPM). The shudder stops if I take my foot off the gas. It also stops when the car shifts into the next gear at about 60 mph. It does not occur when ‘coasting’ (not accelerating) in that speed range. The shudder does not occur in that RPM range at other speeds or in other gears. It does not feel like the engine is stumbling or losing power, but it is a bit disconcerting. The Honda mechanics drove the car and experienced the problem but don’t have an answer. Per the mechanics, the transmission checked out okay and there were no suspect diagnostic codes. Tires were balanced and rotated – several times—without resolving the problem.
I’ve seen similar issues discussed with older Accord models, with suggestions of O2 sensors, throttle position sensor, clogged EGR ports, CV joints and axles. Not sure if any of the above apply here or how to check. Ideas?
Thanks
srquinton is offline   Reply With Quote
Old 08-18-2009, 01:03 AM   #2
FishyMan's Avatar
Default Re: 2004 Accord EX Shudder on Acceleration
Fuel injectors?
Has it had a tuneup?
It seems like a spark/gas/combustion issue. Find another mechanic. Any CEL? It could be oil in the plug tubs. Is it misfiring?
FishyMan is offline   Reply With Quote
Old 08-18-2009, 09:10 AM   #3
New User
Thanks for the reply. The car is current with all scheduled maintenance (by the dealer) and runs well other than this specific event under these specific conditions. No CEL or other diagnostic errors noted.
Old 08-24-2009, 11:37 AM   #4
phootbag's Avatar
You will likely find galling on the inner cv joint in one or both axles. Based on your symptom description and my experience...
phootbag is offline   Reply With Quote
Excessive Vibration and Steering Wheel Wobble at High RPM (93 VTEC 5spd) HooliganBB1 Honda Prelude 2 08-08-2016 09:30 AM
Shudder problem burg1121 Honda Accord & Crosstour (2003 - Current) 3 11-25-2013 06:52 AM
94 Accord EX shuddering at constant speed disastar Honda Accord (1990 - 2002) 10 01-06-2013 12:44 PM
Thumping under acceleration Resjudicata Honda Accord & Crosstour (2003 - Current) 5 10-21-2012 07:08 PM
5 speed shudders in 1st gear flyboy1 Transmission & Drivetrain 5 10-08-2012 06:42 AM
Tags
2002, 2004, 50, 60, accelerating, acceleration, accord, civic, crv, engine, honda, mph, past, shudder, shudders
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
