2003 Honda Accord Left Dashboard Turn Indicator & Blinkers Not Working - Honda-Tech
Old 03-14-2008, 07:50 PM   #1
cancoo's Avatar
Default 2003 Honda Accord Left Dashboard Turn Indicator & Blinkers Not Working
The left turn indicator on my dashboard and both front/rear blinkers are not working all of a sudden. I looked in the owner's manual to see if a fuse was obviously related to this but am not seeing anything.
Any ideas?
Thanks
cancoo is offline   Reply With Quote
Old 03-14-2008, 09:03 PM   #2
HondaTechAV6's Avatar
Default Re: 2003 Honda Accord Left Dashboard Turn Indicator & Blinkers Not Working (cancoo)
oddly enough, i just had this issue last week. it turns out the turn signal flasher relay has two relays in it now, one for each side. this is different from previous designs. replaced the turn signal flasher to start with.
HondaTechAV6 is offline   Reply With Quote
no blinkers/hazards left dash indicator solid won't turn off, nothing on the right Natalie Harvey Lighting 0 03-02-2014 09:36 PM
1995 Accord Electrical Issue Mario Locatelli Honda Accord (1990 - 2002) 2 10-02-2013 06:16 AM
Left blinkers not working Honda Accord 2005 wasabijim Honda Accord & Crosstour (2003 - Current) 0 05-09-2011 07:32 PM
Highbeams & blinkers work but not the related cluster indicators 6SPD_EK Acura RSX DC5 & Honda Civic EP3 3 11-03-2009 01:18 PM
blinker problem (already did a search) hybridbmw Honda Civic / Del Sol (1992 - 2000) 5 06-18-2004 07:50 PM
Tags
03, 2003, accord, dashboard, flasher, honda, indication, indicator, left, location, problem, relay, signal, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
