Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Couldn't find ATF filler bolt...oil jet kit WTF?
Old 04-14-2012, 04:47 PM
gstephen70's Avatar
Default Couldn't find ATF filler bolt...oil jet kit WTF?
Seems my Accord has a oil jet kit installed to reduce temp to second gearing. Funny as the only vehicles affected by this TSB were Pilot's and Oddy's.
Weird?
So I guess tomorrow I'll spend a few hours holding up a funnel while the ATF fluid slowly drips into the dipstick hole. Sounds like fun.
Anyone know anything about this? Any alternatives? I was thinking of disconnecting the oil jet kit hose and adding fluid through the rubber tubing.
Take a look.
File Type: pdf
Old 04-14-2012, 05:26 PM
BLKFLSH's Avatar
Default Re: Couldn't find ATF filler bolt...oil jet kit WTF?
I have an 03 V6 Accord with the jet kit installed. I just remove the bolt on the bracket, holding the jet kit tube into the filler bolt hole, pull the tube out, and fill through there. The jet kit tube goes down into the transmission an inch or two. Easy.
Old 04-14-2012, 05:52 PM
ekb16's Avatar
yup just remove the 10mm bolt n pull the jet out n fill thru the hole
Old 04-15-2012, 06:11 AM
gstephen70's Avatar
Thanks guys. I didn't want to have to go through the dipstick. Quicker is better, as long as it don't make a mess.
aZnPIGbOi
02-06-2006 05:26 PM
ste_smith
04-11-2002 04:25 PM
Quick Reply: Couldn't find ATF filler bolt...oil jet kit WTF?
